• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Change the directory of the digital editions library
New Here ,
Jun 23, 2013 Jun 23, 2013
I want to change the standart directory "C:\Users\...\Documents\My Digital Editions" for the library to a custom one. Is it possible?
Views
6.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Jun 24, 2013 Jun 24, 2013
Moving this discussion to the Adobe Digital Editions forum.
Jan it is not possible to customize the location of the My Digital Editions folder within Adobe Digital Editions.
Votes
Translate
Translate
Adobe Employee ,
Votes
Translate
Translate
Report
Report
Guide ,
Jun 25, 2013 Jun 25, 2013
As Jeff says, ADE is too unhelpful to allow this.
If you are a little technical, you can do it using symbolic directory links.
  1. Move the "C:\Users\...\Documents\My Digital Editions" to wherever you want it, for example "d:\My Digital Editions"
  2. You might make a safe copy as well, just in case.
  3. Open a command prompt as administrator.  Type cmd in start menu, right click on cmd.exe and 'run as administrator'
  4. Run the command    mklink /d "C:\Users\...\Documents\My Digital Editions" "d:\My Digital Editions"
  5. Quit the command promt with exit
Votes
Translate
Translate
Report
Report
Community Beginner ,
Dec 07, 2021 Dec 07, 2021
This is a great solution, thanks so much! For Mac users, here's the equivalent:
  1. Make a backup of your Digital Editions folder.
  2. Assuming you have iCloud Drive set up, move the Digital Editions folder to iCloud Drive (wherever you like).
  3. In Terminal, create a symbolic link in your Documents folder, directing to the iCloud version:
ln -s /Users/[username]/Library/Mobile\ Documents/com\~apple\~CloudDocs/[whatever_location]/Digital\ Editions /Users/[username]/Documents
Note that it works perfectly on Mac OS Monterey, but only partly for Mojave. On my Mac running Mojave, it didn't manage to find the library, and only a couple of books appeared and worked properly (those purchased directly via Adobe account).
To work well across both Mac OS versions, what worked for me was keeping everything local on the Mojave-running Mac, except for the Annotations folder. I then created a symbolic link for that folder only:
ln -s /Users/[username]/Library/Mobile\ Documents/com\~apple\~CloudDocs/[whatever_location]/Digital\ Editions/Annotations /Users/[username]/Documents/Digital\ Editions
 That seems to be working fine.
Note that you can drag folders from Finder into the Terminal window, to save having to type all that.
Really disappointing that Adobe doesn't bother to include such basic functionality, provides no support for ADE, and yet continues to hold a monopoly.
Votes
Translate
Translate
Report
Report
PS I got carried away describing the fix I was looking for, and forgot the OP's actual question.
If you only want to change the folder's location, it's even easier:
  1. Still make a backup of your Digital Editions folder 🙂
  2. Move the Digital Editions folder to the new location.
  3. In Terminal, use this command to set up the symbolic link:
ln -s [new_location]/Digital\ Editions /Users/[username]/Documents
Note that the new location has to be the full file path. The easiest way to enter the folders' paths is to type ln -s (but don't hit enter), then drag the new file folder from Finder into the Terminal window, then drag the Documents folder the same way. The new folder, wherever it is, should still be called Digital Editions, though, so ADE thinks it's looking in the expected place.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 30, 2023 Jul 30, 2023
Does this still work? I might be doing something wrong, but just tried these steps and the folder is being recreated in the original location.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Forgot to say: I am trying the Windows version.
Votes
Translate
Translate
Report
Report
