12 Replies Latest reply: Aug 26, 2014 6:32 AM by moose422 RSS
    Creative Cloud failed to install
    arambas Community Member
      I signed up for Creative Cloud a little over a month ago and downloaded up couple of the applications using the Adobe Application Manager. Today I went to grab Dreamweaver for a project I am about to start and when I clicked on the Adobe Application Manager, it downloaded the new Creative Cloud Desktop installer. I received the following error message: ADOBE INSTALLER - We've encountered the following issues: Creative Cloud failed to install. I searched on the forums here and downloaded the cleaner software and went through that entire procedure with exactly the same results. How do I get these applications when the Creative Cloud Desktop software is not installing on my computer?
      I have a Windows 7 32-bit PC.
      Thanks!
      Aram Basmadjian
        • 1. Re: Creative Cloud failed to install
          Abhijit Kr. Employee Hosts
          Please check whether Creative Cloud is showing in Add or Remove Programs if found please uninstall it.
          Please delete OOBE Folder from these locations
          C:\Program Files\Common Files\Adobe
          C:\Users\(Your Username)\AppData\Local\Adobe
          After deleting these folders please download creative cloud from creative.adobe.com and let us know if it works for you or not.
          Regards,
          Abhijit
          • 2. Re: Creative Cloud failed to install
            Creative Cloud is not showing in Add/Remove Programs. I have already deleted the OOBE folders and tried to re-install. I am getting the same error message as before.
            • 3. Re: Creative Cloud failed to install
              bhatnaga Adobe Employee
              Can you please post PDApp log from your machine? This log file is present in temp folder of windows which can be quickly accessed by typing %temp% and then Enter key in the run dialogue or you can do this in navigation bar in any open window of windows explorer.
              Regards,
              Anirudh
              • 4. Re: Creative Cloud failed to install
                The file is 4.49Mb. How do I attach it to this post?
                • 5. Re: Creative Cloud failed to install
                  I sent you my email id in a private message. Send it there. Also, look in folder C:\Program files\Common Files\Adobe\OOBE\PDApp. Is there a folder with _bkp next to it? IF so tell me its name.
                  Regards,
                  Anirudh
                  • 6. Re: Creative Cloud failed to install
                    There is not a folder with _bkp next to it.
                    I have emailed you the log file.
                    Thanks!
                    • 7. Re: Creative Cloud failed to install
                      hannelealanko Community Member
                      I have the same problem. I had (my personal) CS6 installed and needed to install the CC which universitys ordered for me to get the dreamweaver HTML5 support. For 16 days. i was not able to solve this problem. Today I managed to get the installation work. Solution: I had to uninstall the CS 6 installation. This was not great solution cause all my settings gone now. ALSO it's not optimal solution cause I want to use CS6 and CC at the same time. and continue to use my CS6 after I stop using the universitys CC.
                      Now after calling the Adobe tech support I have the CS6 packets downloading and we'll see if I'm able to install the CS6 after uninstalling it and then installing the CC.
                      I let you know. And cause I don't think this solution is good enough (more like work around) I would like to send You (Anirudh) my PDApp log from time before I uninstalled the CS6 and the CC installation kept on failing. Still now the Adobe application Manager keeps on failing. So I'm not so high hopes whit the downloading and reinstalling the CS6. (I still have my other computer with the original problem (=CS6 still not uninstalled and CC failing to install)
                      I also hope you can reset the CC  subscription cause I have not been able to use it for the fisrt 16 days because of software error. The CC subscription is not under this account cause it's ordered by the university Tech support but I can give you the info of the account.
                      • 8. Re: Creative Cloud failed to install
                        tscudder Community Member
                        I had a slightly different issue, CC would install but would not load the sign in prompt...just a blank page.  The steps from Abhijit resolve my issue.
                        • 9. Re: Creative Cloud failed to install
                          squarasotan Community Member
                          Abhijit Kr.,
                          I found this worked for me, thank you.
                          But I must say I forgot to delete the OOBE (out-of-body experience?) files. I simply uninstalled CC and then went to creative.adobe.com and downloaded CC, and installed it from the download.
                          • 10. Re: Creative Cloud failed to install
                            OOBE (Out of Box Experience)...it's what a user experiences the first time they use a product.
                            • 11. Re: Creative Cloud failed to install
                              Petbabe Community Member
                              Nothing is working for me.  I have followed the instructions in this post and the ones listed here: App doesn’t open | Progress wheel spins continually
                              I have uninstalled and reinstalled and restarted my computer after each step.  I have ran the Creative Cloud Cleaner Tool twice.
                              Still a blank white screen (after the progress wheel stops).    Adobe...I want to give you money, please fix this or provide a working work-around.
                              • 12. Re: Creative Cloud failed to install
                                moose422 Community Member
                                I am having the same problem and I have tried everything, adobe please help me!
