3 Replies Latest reply on Jun 10, 2015 12:25 PM by Erik Dillinger
    Photoshop CC, Disable Double-Click Isolation with Path Selection Tool
    Summertime Media
      When working with Paths in photoshop, I have developed a work flow that revolves around adding anchor points to an existing path and repositioning the added anchor point with the Direct Selection Tool. The Issue I am having is whenever I create an anchor point and attempt to move it too quickly, that it instead enters isolation mode and the point is not moved. The result either having to greatly reduce the speed at which I work or repeat the movement several times until it works.
      Is there a way to disable this feature?
