3 Replies Latest reply: Jun 25, 2013 7:13 AM by Zjuka RSS
    PPro CC crashes when using Track Select tool
    Zjuka Community Member
      This is probaby the most bizzare bug i have encountered so far - everythig works - i can scub, play and adjust footage, apply effects, titles and time remapping, but when i select Treack Select tool and click on the timeline, Premiere Pro crashes.
      This is a new develpment as well - i was able to use PPro CC just fine since i installed it (trial version), until yesterday.
      No new applications or updates for Windows, Nvidia card or Adobe were installed lately, but all drivers are up to date (according to various update managers)
      Premiere CS6 works fine with the same sequence (mixed RED and DSLR footage)
      Problem signature:
        Problem Event Name:    APPCRASH
        Application Name:    Adobe Premiere Pro.exe
        Application Version:    7.0.0.342
        Application Timestamp:    5176598d
        Fault Module Name:    ntdll.dll
        Fault Module Version:    6.1.7601.17725
        Fault Module Timestamp:    4ec4aa8e
        Exception Code:    c0000005
        Exception Offset:    0000000000052fc6
        OS Version:    6.1.7601.2.1.0.256.1
        Locale ID:    1033
        Additional Information 1:    1ce0
        Additional Information 2:    1ce04770b02f823ff20b7f82076eba51
        Additional Information 3:    c192
        Additional Information 4:    c19212ee5e1e8407cb093e848f6cb5d8
      System specs:
      Creative Suite CS6 subscription
      Creative Cloud trial
      Windows 7 x64, SP1
      Nvidia Quadro 4000 GPU
      i7-3039k CPU
      32Gb of RAM
      thank you
        • 1. Re: PPro CC crashes when using Track Select tool
          JSS1138 CommunityMVP
          I use the tool quite a bit and haven't had any issues yet.  Unfortunately, I also don't have any ideas why you are.
          Have you tried other sequences, other projects, other media?
          • 2. Re: PPro CC crashes when using Track Select tool
            UlfLaursen Community Member
            Maybe you could try and make a new project in CC, new sequence like the other and import the same footage into the new one. Maybe it is an "import old project into new version" issue?
            Just a guess.
            Ulf
            • 3. Re: PPro CC crashes when using Track Select tool
              Yep, buggy project..
              New project with same and different footage works fine
              Other project created in CC works fine
              Imported sequence from CS6 works fine
              Imported sequence from a buggy CC project into a new project causes crash on using Track Select tool
              I was able to revert the project in question to CS6 via Final Cut Pro XML, also works fine (for now, at least), just have to redo some time remapping which didn't come through with XML translation, small loss
              I guess i'll wait few more months before switching to PPro CC, maybe mysterious bugs will be worked out by then
              Thank you for your replies!
