0 Replies Latest reply: Jun 25, 2013 7:23 AM by phipm1 RSS
    Swf file wont play from httpserver, windows opens up but doesn't play, but works fine from SunOne
    phipm1 Community Member
      We currently migrating over to http server from SunOne web server.  When you run the launch.html file an additional browser window opens but the swf doesn't not start playing.
      The new http server is using exactly the same doc root as SunOne.
      I have swf in the mime types and i've checked all the permissions .
      Conf File
      Include /opt/IBM/WebSphere/HTTPServer/conf/httpd.conf
      Listen 1xxxx
      DocumentRoot "/www/edc/docs"
      <Directory />
          Options FollowSymLinks
          AllowOverride None
      </Directory>
      <Directory "/www/edc/docs">
      </Directory>
      ######### DirectoryIndex ############################################
      directoryIndex index.html index.htm
      IndexOptions FancyIndexing VersionSort
      ########## Pidfile location,Error and Access Logs #####################
      PidFile /opt/IBM/WebSphere/HTTPServer/logs/edc/httpd.pid
      ErrorLog "|/opt/IBM/WebSphere/HTTPServer/bin/rotatelogs /opt/IBM/WebSphere/HTTPServer/logs/edc/error_%Y-%m-%d-%H:%M 86400 -360"
      CustomLog /opt/IBM/WebSphere/HTTPServer/logs/edc/access_log common
      CustomLog "|/opt/IBM/WebSphere/HTTPServer/bin/rotatelogs /opt/IBM/WebSphere/HTTPServer/logs/edc/access_%Y-%m-%d-%H:%M 86400 -360" common
      LogLevel warn
      # The following directives define some format nicknames for use with a CustomLog directive
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
      LogFormat "%h %l %u %t \"%r\" %>s %b" common
      LogFormat "%{Referer}i -> %U" referer
      LogFormat "%{User-agent}i" agent
      Alias /icons/ "/opt/IBM/WebSphere/HTTPServer/icons/"
      <Directory "/opt/IBM/WebSphere/HTTPServer/icons">
          Options Indexes MultiViews
          AllowOverride None
          Order allow,deny
          Allow from all
      </Directory>
