3 Replies Latest reply on Jun 25, 2013 12:54 PM by Ned Murphy
    Modifying variables to go up and down on certain frames
    Cool Colors Level 1
      I have declared these vars in the root:
      var nrpers:Number = 38;
      var zero:Number = 16;
      I need to modify these two vars  using two conditions:
      1. at each 12 frames and if i'm rollover on the play button (isplaying is true means i'm rollover the the play button)
      2. at each 12 frames and if i'm rollover on the rewind button (isrewinding is true means i'm rollover the the rewind button)
      Update here:
      the following code is inside a movieclip called "roata" that is in the _root.
      this.onEnterFrame = function()
          if ((this._currentframe % 12 == 0) && (_root.isplaying == true))
              if (_root.nrpers == 1)
                  _root.nrpers = 38;
              _root.nrpers = _root.nrpers - 1;
              if (_root.zero == 0)
                  _root.zero = 16;
              _root.zero = _root.zero - 1;
              trace(_root.zero);
              trace(_root.nrpers);
              _root.roata["orbiter" + _root.zero.toString()]["spinner"]["personaj"].gotoAndStop(_root.nrpers);
      // the above code makes _root.zero to go like this 15-0, 15-0, ... in a  loop
      // also the above code makes _root.nrpers go from 37-1, 37-1, ...  in a loop
      // That is exactly what I want that code to do. It works great.
      // what I want is that the below code to go like this:
      // _root.zero to go from 0-15, 0-15, ... in a loop
      // _root.nrpers to go from 1-37, 1-37, ... in a loop
      // but it doesn't seem to work and I can't fix it even though I really tried, i'm missing smth, i'm in a "box"
      // the below code gives the following results:
      // _root.zero goes from 0-16, 0-16 ... in a loop   - so here I need 0-15, 0-15,... in a loop
      // _root.nrpers goes from 1-38, 1-38 ... in a loop - and here I need 1-37, 1-37, ... in a loop
          if ((this._currentframe % 12 == 0) && (_root.isrewinding == true))
              if (_root.nrpers == 38)
                  _root.nrpers = 0;
              _root.nrpers = _root.nrpers + 1;
              if (_root.zero == 16)
                  _root.zero = -1;
              _root.zero = _root.zero + 1;
              trace(_root.zero);
      Keep in mind when you make suggestions to modify the code that doesn't work or the root variables that it may affect the code that works. I need both code parts to works in conjunction modifying up and down those two variables. I tried to make this as clear as possible. Ask questions if something is unclear.
        • 1. Re: Modifying variables to go up and down on certain frames
          Try changing the test limit to be like the count up version where it tests the desired end value and not one less/more...
                  if (_root.nrpers == 37)
                      _root.nrpers = 0;
                  if (_root.zero == 15)
                      _root.zero = -1;
                  trace(_root.zero);
                  _root.roata["orbiter" + _root.zero.toString()]["spinner"]["personaj"].gotoAndStop(_root.nrper s);
          • 2. Re: Modifying variables to go up and down on certain frames
            Cool Colors Level 1
            Using your code:
            I'm getting for _root.nrpers
            39
            40
            41
            42
            and for _root.zero
            17
            18
            19
            20
            Your code works if I modify the initial values of the variables like this
            _root.nrpers = 37;
            _root.zero = 15;
            But now my other code doesn't work as it should.
            _root.zero skips 15 the first time and shows:
            14-0, 15-0,15-0
            _root.nrpers skips 37 the first time and shows:
            36-1, 37-1, 37-1
            • 3. Re: Modifying variables to go up and down on certain frames
              Yes, either you need to use separate variables for forward versus backqard, or you need to adjust the initial value for each different case.
