7 Replies Latest reply on Aug 5, 2006 2:05 PM by Darth Crap
    Wierd Things Happening
    Darth Crap Level 1
      Two things wierd going on with my flash project atm.
      Any help or ideas would be appreciated
      1.
      I have a movie clip called chao with the name 'chao', which contains another movieclip called 'chao4' with the name 'mychao'
      (yes... i am doing a sonic game lol)
      Later on, i have the a script which uses removeMovieClip(chao.mychao) to remove the inside chao, so then chao.attachMovie("chao"+chaoid,"mychao",chao.getNextHighestDepth()) can be called.
      But.... the removeMovieClip is not working (neither for that meatter is attachMovieClip)
      If you use trace(chao + " - CHAO \n " + chao.mychao + " - MYCHAO"); you can see both still exists - as well as if you look on the stage.
      Can anyone tell me what is happening?
      2.
      This is not to do with actionscript, but is for the same project so i put it in the same topic :p
      I have four animated menu items
      In the libary they are named menuitem_battle, menuitem_maingame and so on.
      Before the menu items actuall 'activate' the zoom onto the stage at different intervals
      But... then they don't work in the actual menu once 'activated'
      However...
      If i duplicate each menu item in the libary to get menuitem_*whatever* copy, and change the objects on the actual 'menu' to the copies, it works fine?
      Any ideas why?
