2 Replies Latest reply on Jun 25, 2013 5:05 PM by mytaxsite.co.uk
    Error Code 1
    JamesNov
      I had problems with Photoshop Premier Elements 8 crashing.  I uninstalled both Elements and Premier Elements 8 and reinstalled them.  Now when I try to open either program I receive a message with error code 1 on it.  Can anyone help me with this problem?
        • 1. Re: Error Code 1
          Brett N Adobe Employee
          There are a number of possible causes of this error. It could some damaged files in the application (often resulting from an interupted installation process), damaged files in the OS, damaged settings files, modified system settings, etc.
          If an uninstall and reinstall did not fix the issue, try running the software from a new user account to see if that helps to isolate the issue.
          • 2. Re: Error Code 1
            mytaxsite.co.uk Level 6
            Did you install any device or remove any device after you installed the two products?  If so then this error is because of that.  However, you haven't said what is your operating system.
            If your operating system is Windows then I suggest visit Microsoft Website at the following link and run their "Fix" button:
            <http://support.microsoft.com/kb/310123>
            G/L
