2 Replies Latest reply on Oct 11, 2007 6:09 PM by Captiv8r
    Recording Modes
    usf8197 Level 1
      I'v chosen to record both a demo and assessment by checking the related mode boxes in the window. Captivate records both until I end a recording event. When I start to record again, the screen only shows the demonstration mode and not the other modes. How can I get it to continue recording in both modes for the rest of the project?
        • 1. Re: Recording Modes
          macrofireball Level 3
          Hi there,
          Unfortunately when adding screen action to an existing Captivate project you cannot use the multiple recording modes option introduced in Adobe Captivate 3. If this is something that you would like to see in a future version please feature request using the Adobe Captivate Feature Request/Bug Report Form
          HTH
          Regards - Mark
          • 2. Re: Recording Modes
            Hi usf8197 and welcome to our community
            One way that you might accomplish this would be as follows:
            Record in multiple modes. Sounds as if you have that one covered.
            If you have ended, you might simply try recording the remaining bits as a new project. If you do this, multi-mode should again be available. So record the additional data and save.
            Now you should be able to open each of the first projects and import the slides and objects from the new recording so you might extend the recording as desired.
            Just a thought... Rick
