4 Replies Latest reply on Jun 27, 2013 2:58 AM by Andrew_S
    Working on 1 project between 2 computers
    Flavio72 Level 1
      I have a Mac Pro in the office with Premire Pro CS6 and an iMac with Premiere Pro CS6 at home.
      I would like to start up a PP project in the ofice and then work on the same project at home. Then when I return to the office I update my project with the work I have done at home.
      Is there a way of doing this with PP?
      Thanks.
        • 1. Re: Working on 1 project between 2 computers
          Fuzzy Barsik Level 4
          If you have enough disk space on both machines to store your media files, you just need to move .prproj file between them. Otherwise consider having external drive (preferably eSATA one or at least USB 3.0 in order not to create a bottleneck) for media files and Media Cache Database so as to avoid reconforming every time you launch the project.
          • 2. Re: Working on 1 project between 2 computers
            Flavio72 Level 1
            So if I do put my media files on both mahcines how do i thne connect the .prproj file the first time i move from one machine to the other?
            And after that do I jsut delete the old .pproj file and replace with the new one and it will work? No re-linking or anything liek that?
            • 3. Re: Working on 1 project between 2 computers
              If full path to your media files, including drive letter, is identical, you simply overwrite the project file (rename old file if you want to keep tracks). If the path is different, you'll have to relink your media files (you'll be asked about missing media on launching the project).
              • 4. Re: Working on 1 project between 2 computers
                Andrew_S Level 3
                Having all files on an external HDD works OK. At least with HDV material. You then just carry the HDD between machines.
                The only problem with having two copies of the media (one on each machine) is that sometimes you or premiere renders out extra files as part of the editing process, EG rendering an effect that has a red bar over it or using render and replace. Those files will only exist on one machine - unless you find them and copy them to the exact same place on the other machine.
