0 Replies Latest reply on Oct 11, 2007 8:20 AM by jsather2
    Flex Ant and External SWCs
    jsather2
      I'm working on integrating our flex builds into our continuous integration system (CruiseControl) using ant and the ant flex tasks. I based the ant script off the one that came with the Cairngorm library. I have an SWC project with no dependencies compiling fine. The problem is when I need to add in an external SWC to the compc task. Here is what I have:
      <compc
      output="${output.swc}"
      locale="${application.locale}"
      allow-source-path-overlap="true"
      headless-server="true"
      warn-no-constructor="false">
      <!-- Config file. -->
      <load-config filename="${config}" />
      <source-path path-element="${flex.src.dir}" />
      <!-- List of SWC files or directories that contain SWC files. -->
      <external-library-path dir="${flex.sdk.home}/frameworks/libs" append="true">
      <include name="*.swc" />
      </external-library-path>
      <external-library-path dir="../company-valueobjects/bin" append="true">
      <include name="company-valueobjects.swc" />
      </compc>
      The problem seems to be that it won't recognize the libraries in the company-valueobjects.swc file. Here is the error:
      [compc] Error: could not find source for class Company.InteractiveCharter.Aggregator.vo.AdvanceDeclineDataPoint.
      It doesn't seem to find the library from the external-library SWC. The included SWC is compiled in almost exactly the same way (minus the second ext-lib).
      Any ideas on what I might be doing wrong? Has anyone build an SWC where they include libraries from an external SWC?
      Thanks.
