7 Replies Latest reply on Jun 26, 2013 10:20 AM by JS Bournival
    Help! CQ 5.6 as a Windows Service LDAP config
    JS Bournival Level 1
      Hi have this strange problem:
      If I start CQ on the command line using the usual stuff (I'm on Java 1.7)
      "C:\Windows\System32\java.exe" -Xmx1024m -XX:MaxPermSize=256M -Djava.security.auth.login.config=crx-quickstart\conf\ldap_login.conf -jar cq-author-p4502.jar -use-control-port -p 4502 -nobrowser -nofork
      It's picking up my LDAP configuration correctly.  But if I'm using the windows service, I was never able to make it pick up my configuration.
      LOG:
      26.06.2013 10:29:58.328 *ERROR* [FelixStartLevel] org.apache.jackrabbit.core.DefaultSecurityManager Neither JAAS nor RepositoryConfig contained a valid configuration for com.day.crx
      26.06.2013 10:29:58.328 *ERROR* [FelixStartLevel] org.apache.jackrabbit.core.RepositoryImpl failed to start Repository: Neither JAAS nor RepositoryConfig contained a valid configuration for com.day.crx javax.jcr.RepositoryException: Neither JAAS nor RepositoryConfig contained a valid configuration for com.day.crx
      Very frustrating.  Can somebody help me figure this out please? It's important.
      Here is my start-service.bat file configuration section:
      ::@echo off
      setlocal
      :: This script configures the windows service start information for this server.
      :: The following variables may be used to override the defaults.
      ::* TCP port used for stop and status scripts
      set CQ_PORT=4502
      ::* interface that this server should listen to (ip or hostname)
      :: set CQ_HOST=
      ::* show gui
      :: set CQ_GUI=true
      ::* do not show browser on startup
      set CQ_NOBROWSER=true
      ::* do not redirect stdout/stderr (logs to console)
      :: set CQ_VERBOSE=true
      ::* do not fork the JVM
      set CQ_NOFORK=true
      ::* force forking the VM using recommended default memory settings
      :: set CQ_FORK=true
      ::* additional arguments for the forked JVM
      :: set CQ_FORKARGS=
      ::* runmode(s)
      :: set CQ_RUNMODE=
      ::* defines the path under which the quickstart work folder is located
      :: set CQ_BASEFOLDER=
      ::* low memory action
      :: set CQ_LOWMEMACTION=
      ::* name of the jarfile
      :: set CQ_JARFILE=
      ::* use jaas.config
      set CQ_USE_JAAS=true
      ::* config for jaas
      set CQ_JAAS_CONFIG=crx-quickstart/conf/ldap_login.conf
      ::* default JVM options
      set CQ_JVM_OPTS=-Xmx1024m -XX:MaxPermSize=256M
      ::* Uncomment, or redefine one of the follwoing JAVA_HOME if you wish a
      ::  different than your default one
      ::  set JAVA_HOME=c:\java\jdk1.4.2_08
        • 1. Re: Help! CQ 5.6 as a Windows Service LDAP config
          dcollie Adobe Employee
          Use the full path to your ldap_login.conf in your script and try again (alter crx-quickstart/opt/helpers/start-service.bat for when running as service)
          If still broke, what's the output of the command to start if you run the service-start.bat on the command line.   Check and make sure the -D arguments occur all before the cq-author-p4502.jar file.   In older start scripts the command ends up being something similar to:
          "C:\Windows\System32\java.exe" -Xmx1024m -XX:MaxPermSize=256M -jar cq-author-p4502.jar -use-control-port -p 4502 -nobrowser -nofork -Djava.security.auth.login.config=crx-quickstart\conf\ldap_login.conf
          Rather than:
          • 2. Re: Help! CQ 5.6 as a Windows Service LDAP config
            Thanks for the reply,
            I modified the start-service.bat to use the full path, but same result:
            ::* config for jaas
            set CQ_JAAS_CONFIG=D:\author\crx-quickstart\conf\ldap_login.conf
            As for running the script directly, it fails because it says it cannot find the jar (?).  However, here is the ouput (command line seems OK) :
            D:\author>crx-quickstart\opt\helpers\start-service.bat
            D:\author>setlocal
            D:\author>set CQ_PORT=4502
            D:\author>set CQ_NOBROWSER=true
            D:\author>set CQ_NOFORK=true
            D:\author>set CQ_USE_JAAS=true
            D:\author>set CQ_JAAS_CONFIG=D:\author\crx-quickstart\conf\ldap_login.conf
            D:\author>set CQ_JVM_OPTS=-Xmx1024m -XX:MaxPermSize=256M
            D:\author>cd ..
            D:\>set START_OPTS=-use-control-port
            D:\>if defined CQ_PORT set START_OPTS=-use-control-port -p 4502
            D:\>if defined CQ_GUI set START_OPTS=-use-control-port -p 4502 -gui
            D:\>if defined CQ_NOBROWSER set START_OPTS=-use-control-port -p 4502 -nobrowser
            D:\>if defined CQ_VERBOSE set START_OPTS=-use-control-port -p 4502 -nobrowser -verbose
            D:\>if defined CQ_NOFORK set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork
            D:\>if defined CQ_FORK set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -fork
            D:\>if defined CQ_FORKARGS set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -forkargs
            D:\>if defined CQ_RUNMODE set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -r
            D:\>if defined CQ_BASEFOLDER set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -b
            D:\>if defined CQ_LOWMEMACTION set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -low-mem-action
            D:\>if defined CQ_HOST set CQ_JVM_OPTS=-Xmx1024m -XX:MaxPermSize=256M -Dorg.apache.felix.http.host=
            D:\>if defined CQ_HOST set START_OPTS=-use-control-port -p 4502 -nobrowser -nofork -a
            D:\>if defined CQ_USE_JAAS set CQ_JVM_OPTS=-Xmx1024m -XX:MaxPermSize=256M -Djava.security.auth.login.config=D:\author\crx-quickstart\conf\ldap_login.conf
            D:\>if not defined CQ_JARFILE for %X in (*.jar) do set CQ_JARFILE=%X
            D:\>if not defined JAVA_HOME (call :which java.exe JAVA )  else (set JAVA="\bin\java.exe" )
            D:\>setlocal
            D:\>set res="C:\Windows\System32\java.exe"
            D:\>endlocal & set JAVA="C:\Windows\System32\java.exe"  & goto :EOF
            D:\>if "C:\Windows\System32\java.exe" == "" (
            echo JAVA_HOME not specified and no java.exe in PATH
            goto exit
            D:\>if not exist "C:\Windows\System32\java.exe" (
            echo No JVM found at "C:\Windows\System32\java.exe"
            goto exit
            D:\>"C:\Windows\System32\java.exe" -Xmx1024m -XX:MaxPermSize=256M -Djava.security.auth.login.config=D:\author\crx-quickstart\conf\ldap_login.conf -jar cq-author-p4502.jar -use-control-port -p 4502 -nobrowser -nofork
            Error: Unable to access jarfile cq-author-p4502.jar
            D:\>echo -------------------------------------------------------------------------------
            D:\>echo Starting...
            Starting...
            D:\>call "C:\Windows\System32\java.exe"  -version
            java version "1.7.0_25"
            Java(TM) SE Runtime Environment (build 1.7.0_25-b17)
            Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
            D:\>echo "C:\Windows\System32\java.exe"   -jar
            D:\>"C:\Windows\System32\java.exe"   -jar ""
            D:\>goto exit
            D:\>endlocal
            • 3. Re: Help! CQ 5.6 as a Windows Service LDAP config
              ... and what's funnier is that if I just copy paste and run that line:
              "C:\Windows\System32\java.exe" -Xmx1024m -XX:MaxPermSize=256M -Djava.security.auth.login.config=D:\author\crx-quickstart\conf\ldap_ login.conf -jar cq-author-p4502.jar -use-control-port -p 4502 -nobrowser -nofork
              It works like a charm! :-s
              I'm puzzled.
              • 4. Re: Help! CQ 5.6 as a Windows Service LDAP config
                You would need to make sure you launched the service-start.bat from the "crx-quickstart\opt\helpers" directory, as it's doing tree traversal to find the CQ jar file. (got that wrong )
                You need to start from "crx-quickstart" folder, e.g.: D:\Tools\CQ\5.6-GM\crx-quickstart>opt\helpers\start-service.bat
                Try setting full path using the variable in the script?
                :: set CQ_JARFILE=
                • 5. Re: Help! CQ 5.6 as a Windows Service LDAP config
                  yup, working.  but still no luck from the windows service.  Does it even use this script (start-service)?? I put garbage in it and still it starts.
                  • 6. Re: Help! CQ 5.6 as a Windows Service LDAP config
                    Have a look at the instsrv.bat, it did in earlier versions, will test 5.6 tomorrow.
                    Or try this http://cqquest.blogspot.ie/2012/05/ldap-fail-in-cq55.html
                    • 7. Re: Help! CQ 5.6 as a Windows Service LDAP config
                      working.  Documentation should make clear how to cope with this.
                      thanx for your help.
