0 Replies Latest reply on Jun 27, 2013 10:20 AM by kellisswan
    Responsive animation difficulty - stage height fixed?
    kellisswan
      I just created my first, fairly simple edge project - a header for my website. I made the project responsive, and it works well on preview in browser. However when I inserted it into Dreamweaver, it was not responsive, so I added an embed class with width=100% and height=auto. That did indeed cause the edge animation images to respond nicely, however there appears to be a fixed stage height involved, and I can't figure out how to fix it.  As my navigation bar falls just below this header graphic, the nav gets pushed way down on smaller devices.
      Also, when I add the embed class, the entire graphic becomes hidden while working in Dreamweaver, except when viewing as "Live". I took out the height=auto as it wan't having the desired effect anyways, and then I could see the graphic in Dreamweaver again.
      Here's what I have so far: http://www.pencilplace.com/
      Member "BigMucho" posted the following teak on another thread [http://forums.adobe.com/message/5234102#5234102]. This does work for me ... will use this unless/until somebody can shed other, easier light on the subject of making an animation responsive for width & height.
      *** Posted by BigMucho***
      A few tweaks to the Edge HTML / CSS and you're good to go.  Inside Edge, make sure all height and width units are set to percentage (including the stage).  This technique also works well with non-Edge content, no jQuery required.
      HTML:
      <body>
          <div id='aspectwrapper'>
              <div id='content'>
                  <!-- The Good Stuff Lives Here -->
              </div>
          </div>
      </body>
      CSS:
      #aspectwrapper {
                display:inline-block;
                width:100%;
                position:relative;
      #aspectwrapper::after {
                padding-top:56.25%;
           // Use this percentage for 16:9, get yours via: Height / Width * 100
                display:block;
                content:'';
      #content {
                position:absolute;
                top:0;
                bottom:0;
                right:0;
                left:0;
                overflow:hidden;
