• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RoboHelp and HTML
Guest
Oct 10, 2007 Oct 10, 2007
I'm new to RoboHelp and am looking into purchasing. However, before I do, I have a few questions I would like to clear up first.
If I create an HTML file, can I import it into RoboHelp (i.e. I'm trying to create a template in RoboHelp starting from HTML. By the way, does RoboHelp have the concept of a template (as in MS Word)?
Thank in advance for the help!
Views
396
Translate
Translate
Report
Report
Community guidelines
community guidelines
Deleted User
Creating a template is very easy, I think--you go through a short dialog to set up a title and file name and specify a style sheet. You can change those attributes later if you want.
RH has a WYSIWYG editor as well as a code editor, so you do the rest there to make the template look the way you want.
--Ben
Votes
Translate
Translate
Guest
Welcome to the forums.
Yes, you can import HTML files, and yes, RoboHelp has templates. Importing an HTML file to use as a template requires an extra step because RH's templates have a file extension of .htt. With your HTML file open in an editor like Notepad, you can do a "Save As" and save a copy with a .htt file extension, and then import it into RH's Templates folder in the Project Manager.
Ben
Votes
Translate
Translate
Report
Report
Guest
Thanks for the reply Ben.
One more question, is creating a template in RoboHelp easy?
Thanks.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Hi suspiration and welcome to our community
You may find the following link useful when you work with Templates.
Click here
Cheers... Rick
Votes
Translate
Translate
Report
Report
Guest
--Ben
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
