3 Replies Latest reply on Oct 23, 2007 6:30 AM by stu legend
    Curving words
    stu legend
      I want to write a few words then bend them into a semi circle shape. I know this can be done in Photoshop but wanted to know if it could be done in Fireworks version MX2004. If it can't be done is there any add-on software I could down load ? Please help! Cheers.
        • 1. Re: Curving words
          Level 7
          Easy to do in MX2004. Type the text. Draw a circle (ellipse tool with
          shift key held down). Select text and circle. The from the menu bar:
          Text > Attach to path
          Experiment with different size circles etc. If you just want the text
          curving and no curve visible, set both the fill and the stroke to none.
          DN
          • 2. Re: Curving words
            stu legend Level 1
            Cheers for the help I'll try that!
            • 3. Re: Curving words
              stu legend Level 1
              Hi David
              Thanks for your help on curving the words a while back. My new problem is curving the words in 2 directions. At the moment I can only curve the letters one way around the circle (from the top of the cirlce) But if I want the letter to follow the curve at the bottom of the circle it doesn't work. It just bounces to the top of the circle. I've tried a few things but have no idea how to do this task. Any help would be very much appreciated.
              Cheers
              Stu
