4 Replies Latest reply on Jun 30, 2013 12:43 PM by haley_e_2013
    Saved TOC style not showing up for EPUB export
    haley_e_2013 Level 1
      I created and saved a new TOC style, tested it in its own document to make sure it looked right, added that doc to my Book file, saved everything, and went to export my ebook. In the "TOC Styles" dropdown menu, the only two TOC styles avaiable are "Default" and "No Style," and my saved style does not show up. Any idea why?
      Other info:
      - I'm running a trial version of Adobe InDesign CS6
      - I'm on a PC
      - I haven't yet tried resetting my preferences, but want to avoid that if at all possible
      I did ask this question before, but wasn't clear about the problem because I didn't fully understand it myself. Hope it's okay that I'm rephrasing it for clarity now. Thanks!
        • 1. Re: Saved TOC style not showing up for EPUB export
          suripappu
          hi,
          tell application "Adobe InDesign CS5"
                       tell active document
                      try
                          set NewToc to TOC style "BookMarkTocStyle1" -- Already Created style
                      on error
                          set NewToc to make TOC style with properties {name:"BookMarkTocStyle1"} -- Newly Created style
                      end try
                  end tell
          end tell
          • 2. Re: Saved TOC style not showing up for EPUB export
            I'm sorry, but I don't understand your directions. Could you be a little more specific? I am also working with InDesign CS6, if that helps.
            • 3. Re: Saved TOC style not showing up for EPUB export
              suripappu Level 1
              By using apple script language,
                          try
                          on error
                              set NewToc to make TOC style with properties {name:"BookMarkTocStyle1"} -- Newly --Created  style
                          end try
                      end tell
              end tell
              create TOC styles(Example:BookMarkTocStyle1) in all document in Book . while exporting to book , In last active document ,try to create all paragragh  styles what u needed.
              • 4. Re: Saved TOC style not showing up for EPUB export
                Hi all! Pooja contacted me by PM and solved my problem. I wasn't creating the TOC from the Style Source document. DUH. I feel like a moron, but I appreciate all the help.
