1 Reply Latest reply on Jun 27, 2013 4:21 AM by Ned Murphy
    want to increase value by mouse on (release)
    Emraan.Khan Level 1
      my script is ................
      import flash.external.*; //so we can use externalInterface
      import QueryString.as;   //so we can use the QueryString Class
      var myPath:QueryString = new QueryString();
      assignVariables();
      //custom function to handle all the query string parameters
      function assignVariables() {
          //if myName parameter exists
          if (myPath.parameters.m1) {
              //assign it to the text of the myName text box
              //unescape() will translate/unencode the url characters
              myName.text = unescape(myPath.parameters.m1);
          if (myPath.parameters.m2) {
              thisUrl.text = unescape(myPath.parameters.m2);
          if (myPath.url) {
              //get the complete url (including any parameters)
              thisUrl.text = myPath.url;
      var st=12;
      thisUrl.text=st;
      my button script is----
      on(release){
          st = st+10;
        • 1. Re: want to increase value by mouse on (release)
          There is nothing wrong with the code you show, though you should not be placing code on objects.  You should use the timeline instead.
          If the real problem is that the textfield does not display the increased value of st, that's because you do not reassign it the new value when you change it
          on(release){
              st = st+10;
              thisURL.text = st;
