1 Reply Latest reply on Jun 27, 2013 3:21 PM by Josh_Corey
    Is it possible to create two columns on one page?
    ChasWill66
      I have created a form but it is too many pages.  Is it possible to create two columns on one page?
        • 1. Re: Is it possible to create two columns on one page?
          Josh_Corey Adobe Employee
          Yes it is, we support adding fields "side by side", when you have a field selected there is a "+" sign to the right that will bring up a vertical form field toolbar which you can add an adjacent field.  You can also use the context (right click) menu and select "Add item beside".  You can also move your existing fields next to one another by dragging and dropping the field, a blue bar appears where the field would drop and if you drag along the right side of the page it will offer to drop the field adjacent others.
          As an example, several of the Templates have the fields in rows.
          We do not offer formatting in actual columns, but you can resize fields to accomplish a two column look with side by side fields.
          Josh
