2 Replies Latest reply on Jun 28, 2013 10:35 AM by Pablo28282
    Indesign CC uses 7.36 gb of space when launched.
    Pablo28282 Level 1
      I'm on a smallish SSD and I noticed my availbe space drops by 7.36gb of space everytime I launch Indesign CC and returns to normal after I quit. What gives? Why would Indesign need that much cahce? Is there a way I can change the location of the scratch disc at least?
        • 1. Re: Indesign CC uses 7.36 gb of space when launched.
          Dov Isaacs Adobe Employee
          If you are running under Windows:
          Are you sure that the space usage isn't due to a dynamic-sized paging file? Look at the size of  C:\pagefile.sys. If that is what is increasing dramatically, it is likely that you are using the default option for a dynamic paging file which may default to a much smaller size when in fact, for usage with programs such as 64-bit InDesign does require a larger paging file due to the larger address space it is using. I don't think you will find that InDesign is creating a > 7 GB set of temp files.
                    - Dov
          • 2. Re: Indesign CC uses 7.36 gb of space when launched.
            Pablo28282 Level 1
            I'm on a mac. I don't know what is happening, thats why I'm posting here I do know that I was getting a "Hard Drive Low on Space" message which pretty much shut down my entire system before clearing out some additional storage space inorder to run the application.
            Here is the difference. These were taken about 20 seconds apart from each other.
            http://o7.no/15NG831
