2 Replies Latest reply on Jul 1, 2013 8:04 AM by rhyswill
    Checkbox help
    rhyswill
      HI,
      I currently using javascript within a PDF to make a form simpler to use. I have a checkbox list with a sub-checkbox list within it (see below)
      When filling in the form I need the user to only be able to check one item for the primary list and then a further item if the chekc the box with the sublist.
      I have been able to achieve this using the following document level code and the mouse up - run javascript option.
      function cbControl()
          var f1 = getField("Eligible activity 1"); (Area benefit checkbox above)
          var f2 = getField("Eligible activity 2"); (limited Clientle checkbox)
          var f3 = getField("Eligible activity 3"); (Housing checkbox above)
          var f4 = getField("Eligible activity 4"); (Jobs checkbox above)
          var f5 = getField("LCB sublist 1"); (Project activity maintains client records checkbox above)
          var f6 = getField("LCB sublist 2"); (Project activity has income eligiblity checkbox above)
          var f7 = getField("LCB sublist 3"); (Project activity is of such a nautre checkbox above)
          var f8 = getField("LCB sublist 4"); (Project activity clients are presumed checkbox above)
          if (event.target === f1) {
              f2.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              f5.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
          if (event.target === f2) {
              f1.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              return;
          if (event.target === f3) {
              f1.value = "Off";
              f2.value = "Off";
              f4.value = "Off";
              f5.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
          if (event.target === f4) {
              f1.value = "Off";
              f2.value = "Off";
              f3.value = "Off";
              f5.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
      function sublistControl()
          if (event.target === f5) {
              f1.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
          if (event.target === f6) {
              f1.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              f5.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
          if (event.target === f7) {
              f1.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              f5.value = "Off";
              f6.value = "Off";
              f8.value = "Off";
              return;
          if (event.target === f8) {
              f1.value = "Off";
              f3.value = "Off";
              f4.value = "Off";
              f5.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              return;
      However no matter what I try, I can not get the 'Eligible activity 2' box to check if some one selects one of the sublists checkboxes. I have tried including the follwoing into the sublistControl code
              f1.value = "Off";
              f2.value = "On"; (also tried f2.value = "Yes";)
              f3.value = "Off";
              f4.value = "Off";
              f6.value = "Off";
              f7.value = "Off";
              f8.value = "Off";
              return;
      But this does not work. Can anybody suggest a solution??
      Kind regards
      Rhys
