7 Replies Latest reply on Jul 2, 2013 4:27 AM by Ned Murphy
    how i can add description tag in xml gallery
    Emraan.Khan
      my xml is....................
      <?xml-stylesheet href="xmldesign.css" type="text/css"?>
      <gallery thumb_width="400" thumb_height="290" gallery_width="400" gallery_height="700" gallery_x=" " gallery_y=" " full_x="1220" full_y="50" >
      <image thumb_url="t1.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      <image thumb_url="t2.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      <image thumb_url="t3.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      <image thumb_url="t4.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      <image thumb_url="t5.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      <image thumb_url="t6.jpg"  full_url="full01.jpg" title="Mango Juice"/>
      </gallery>
        • 1. Re: how i can add description tag in xml gallery
          You could modify each tag in a similar manner as follows....
          <image thumb_url="t6.jpg"  full_url="full01.jpg" title="Mango Juice" desc="description here" />
          • 2. Re: how i can add description tag in xml gallery
            Emraan.Khan Level 1
            but where i put it on my function
            my function is---
            fullPreloader.onLoadStart = function(target)
                    target.createTextField("my_txt",ajit.getNextHighestDepth(),20,0,700,20);
                    my_txt.selectable = true;
                fullPreloader.onLoadProgress = function(target, loadedBytes, totalBytes)
                    target.my_txt.text = Math.floor((loadedBytes / totalBytes) * 00);
                fullPreloader.onLoadComplete = function(target)
                    new Tween(target, "_alpha", Strong.easeOut, 60, 100, .5, true);
                    target.my_txt.text = myTitle;           //////          this is my title
                fullClipLoader.loadClip("full_images/" + myURL,ajit);
            • 3. Re: how i can add description tag in xml gallery
              Look at the rest of your code where you extract the title and the file name.  THat should be enough for you to figure out what you need to do.
              function callFullImage(myNumber)
                  myURL = myImages[myNumber].attributes.full_url;
                  myTitle = myImages[myNumber].attributes.title;
                 myDesc = ..... figure this out based on the above
              • 4. Re: how i can add description tag in xml gallery
                Emraan.Khan Level 1
                its not working...... pls correction in my function......
                   myDesc =  myImages[myNumber].attributes.desc; // new line added by me
                    _root.createEmptyMovieClip("ajit",_root.getNextHighestDepth());
                    ajit._x = _root.full_x = 130;
                    ajit._y = _root.full_y = 32;
                    _root.onEnterFrame = function()
                        wall._alpha = 0;
                        if (_root._currentframe == 2)
                            wall._alpha = 100;
                    this.gotoAndStop(21);
                    var fullClipLoader = new MovieClipLoader("ajit");
                    var fullPreloader = new Object();
                    fullClipLoader.addListener(fullPreloader);
                        target.my_txt._y=480;
                        target.my_txt.textColor = 0xffffff;
                       target.my_txt.text = myDesc;              //   new line added by me
                        target.my_txt._y=280;                           //   new line added by me
                • 5. Re: how i can add description tag in xml gallery
                  What is not working?  Use the trace function to see why it does not work where you say it does not work.
                  • 6. Re: how i can add description tag in xml gallery
                    Emraan.Khan Level 1
                    sir, its working, and showing "desc" ..  but not  showing "title"...
                    <gallery>
                    <image thumb_url="shop1.png"  full_url="full01.jpg" title="Mango Juice" desc="Hello this is my description"/>
                    </gallery>
                       myDesc =  myImages[myNumber].attributes.desc;             //          add by me
                            wall._alpha = 0;
                                wall._alpha = 100;
                            target.my_txt.text = myDesc;               // added by me
                            target.my_txt._y=280;                         // added by me
                            target.my_txt.textColor = 0xffffff;         // added by me
                    • 7. Re: how i can add description tag in xml gallery
                      That is because you are overwriting the title with the description...  first you have...
                      then you reassign it a few lines later with
                      If you want them both to appear in the same textfield then you need to append the description, not assign it...
                           target.my_txt.text += myDesc;
