2 Replies Latest reply on Jul 2, 2013 9:03 AM by anderson.nt
    Not generating OSGI-INF folder
    anderson.nt Level 1
      I am new to OSGI.I have been having trouble to get OSGI-INF folder in generated jar file. I need to have folder structure like as below
      • META-INF
      • OSGI-INF
      • Com.mine.cq
        I am using Eclipse and m2e plugin. When I run my project I am getting BUILD SUCCESS. And I am getting the below folder structure in the generated jar file. Jar does not have OSGI-INF folder.
      • META-INF
      • Com.mine.cq
      Here is my POM.xml
      <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
                <modelVersion>4.0.0</modelVersion>
                <groupId>com.mine.cq</groupId>
                <artifactId>mineCore</artifactId>
                <version>0.0.1-SNAPSHOT</version>
                <packaging>jar</packaging>
                <name>mineCore</name>
                <url>http://maven.apache.org</url>
                <properties>
                          <file.encoding>utf-8</file.encoding>
                </properties>
                <build>
              <defaultGoal>install</defaultGoal>
              <plugins>
                  <plugin>
                      <groupId>org.apache.maven.plugins</groupId>
                      <artifactId>maven-enforcer-plugin</artifactId>
                      <version>1.0-alpha-3</version>
                      <executions>
                          <execution>
                              <id>enforce-java</id>
                              <goals>
                                  <goal>enforce</goal>
                              </goals>
                              <configuration>
                                  <rules>
                                      <requireMavenVersion>
                                          <message>Maven 2.0.7 or higher</message>
                                          <version>2.0.7</version>
                                      </requireMavenVersion>
                                      <requireJavaVersion>
                                          <message>Java 5 or higher</message>
                                          <version>1.5.0</version>
                                      </requireJavaVersion>
                                  </rules>
                              </configuration>
                          </execution>
                      </executions>
                  </plugin>
                  <plugin>
                      <groupId>org.apache.felix</groupId>
                      <artifactId>maven-bundle-plugin</artifactId>
                      <version>1.4.3</version>
                      <extensions>true</extensions>
                      <configuration>
                          <instructions>
                              <Export-Package>
        com.mine.cq.mineCore.*
                              </Export-Package>
                              <Import-Package>
                                  *;resolution:=optional,
                                  javax.servlet;version=2.4,
                                  javax.servlet.http;version=2.4
                              </Import-Package>
        <Private-Package>
        </Private-Package>
                              <Embed-Dependency>
                              </Embed-Dependency>
                          </instructions>
                      </configuration>
                  </plugin>
                  <plugin>
                      <artifactId>maven-scr-plugin</artifactId>
                      <version>1.9.0</version>
                      <executions>
                          <execution>
                              <id>generate-scr-scrdescriptor</id>
                              <goals>
                                  <goal>scr</goal>
                              </goals>
                          </execution>
                      </executions>
                  </plugin>
                  <plugin>
                      <artifactId>maven-scm-plugin</artifactId>
                      <version>1.0</version>
                      <configuration>
                          <goals>install</goals>
                      </configuration>
                  </plugin>
              </plugins>
              <extensions>
                  <extension>
                      <groupId>org.apache.maven.wagon</groupId>
                      <artifactId>wagon-webdav</artifactId>
                      <version>1.0-beta-2</version>
                  </extension>
                  <extension>
                      <artifactId>wagon-ssh</artifactId>
                  </extension>
              </extensions>
          </build>
      <dependencies>
                          <dependency>
                                    <groupId>junit</groupId>
                                    <artifactId>junit</artifactId>
                                    <version>3.8.1</version>
                                    <scope>test</scope>
                          </dependency>
                </dependencies>
      </project>
      Why OSGI-INF folder is not in the .jar file? I need to set some property information in OSGO-INF folder since I have to register my component as a OSGI service. Please guide me to get it done.
      Anderson
        • 1. Re: Not generating OSGI-INF folder
          rajavijaysingh
          can you try running with debug mode and check the log for scr
          • 2. Re: Not generating OSGI-INF folder
            anderson.nt Level 1
            It was problem with my pom.xml. Finally I have created OSGI bundle with maven-scr plugin J Now I have the correct folder structure (OSGI-INF folder). Actually I need to have a reference via sling.getService only. I have installed my osgi bundle in Felix console successfully. The status of the bundle is Active. But the component status is “registered” When I check it in component console. And there is no entry in my service console.
            Here is my java class
            package com.adobe.support.examples.com.adobe.support.examples.osgi.service;
            import org.apache.felix.scr.annotations.Component;
            import org.apache.felix.scr.annotations.Properties;
            import org.apache.felix.scr.annotations.Service;
            import org.apache.felix.scr.annotations.Property;
            @Component(immediate = true, metatype = true)
            @Service
            public class SampleServiceImpl implements SampleService {
            public String sayHello() {
                 return "Hello World!";
            Why component statis is 'registerd' instead of having 'active' Could you please tell me how to fix it?
            Thanks in advance
            Regards,
            Anderson
