1 Reply Latest reply on Oct 8, 2007 4:09 AM by cemkarahanoglu
    getting started with Flex Builder 2
    critical5 Level 1
      Hi I am new to Flex and I would like someone to point me in the right direction to getting started, i will be using this with coldfusion and mysql database, any easy tutorials/books for beginners...for setup?
        • 1. Re: getting started with Flex Builder 2
          cemkarahanoglu
          Hi all estimable Adobe gurus!
          We have developed a project and used a library in the project called "asSQL-0.1alpha.swc". The project works in there where it has been compiled, but it does not work on the server or any other location. For example; it does not work through localhost when we use a patch such as " http://localhost/proje.html". It works only when we use an absolute path such as "c:\appserv\www\proje.html". And this problem occurs only when we add the SWC library into the project.
          So; when we add the SWC library into the Flex project, the project works only by entering the absoluth path and only where it has been compiled.
          We are looking for a solution. Could you help us providing a solution advice, please!
          Thanks in advance!
          Regards,
