1 Reply Latest reply on Jun 30, 2013 8:01 AM by Peter Spier
    Indesign CS6 - Anzahl der letzten Dateien
    JSch
      In Indesign CS6 wird die "Liste der zuletzt verwendeten Dokumente" nicht angezeigt. Unter "Datei - Voreinstellungen - Dateihandhabung" ist der Eintrag der Anzahl grau unterlegt.
      Wo kann ich die Anzahl verändern?
      Mit freundlichem Gruß
      JoSch
        • 1. Re: Indesign CS6 - Anzahl der letzten Dateien
          First, Edit > Menus... and make sure that visibility for the Most Recent list is enabled. Also, there will be no list if there has been a rewrite of the InDesign SavedData file due a program update or preferences repalcement, so try saving a file and see if the list reappears.
          If it does not, and you still cannot change the number of files to include, it's time to try replacing the prefs. See Replace Your Preferences
          Note that you will not see the list (as I mentioned above) until after you start to rebuild it by saving a file, but you should once again be able to specify a number to display.
