8 Replies Latest reply on Oct 9, 2007 4:58 PM by jjay@aus
    Randomly Adjusting Numbers
    jjay@aus
      I need to randomly adjust a large setu of number up 1% or down 2% individually.
      I did write a script whereby I create a random decimal number between 1 and -2 and multiply the originaly number by the result of the random number, but the minus numbers weren't giving me what I expected (you mathematicians out there are probably chuckling to yourself right now I am sure.. but hey.. I tried :).
      Now I am kind of at a loss. Does anyone have any suggestions on how I can randomly adjust a number (e.g.300,000) in a range between 1% increase and 2% decrease?
      Thanks in advance.
        • 1. Re: Random Decimal Numbers
          Level 7
          jjay@aus wrote:
          > I am trying to create random, non-integer numbers between -2 and .2.
          maybe something like this:
          <cfscript>
          now=now();
          random=createObject("java","java.util.Random").init(now.getTime());
          v1=3*random.nextDouble()-2;
          v2=3*rand("SHA1PRNG")-2; // cf8
          writeoutput("#v1# #v2#");
          </cfscript>
          • 2. Re: Random Decimal Numbers
            BKBK Adobe Community Professional & MVP
            The Coldfusion function rand() returns a real number, that is, a decimal number, between 0 and 1 at random. Therefore, 3*rand() is a random real number between 0 and 3. It follows that 98+3*rand() is a random real number between 98 and 101. Hence, 98+3*rand() is the factor you seek.
            However, you have to divide it by 100. For example, a decrease of 2% is equivalent to 98% or 0.98 of the original value. An increase of 1% is equivalent to 101% or 1.01 of the original value. The code follows.
            • 3. Re: Random Decimal Numbers
              Level 7
              wow you completely edited the content & even the title of this thread. in the
              future start a new thread otherwise it's confusing to those of use who use NNTP.
              • 4. Re: Random Decimal Numbers
                Level 7
                wow! yeah! at first i thought BKBK has gone mad...
                strange... i am sure that in the past* all edits to posts came in as new
                posts in nntp...
                * = before Adobe's attempt at upgrading the forums
                Azadi Saryev
                Sabai-dee.com
                http://www.sabai-dee.com
                • 5. Re: Randomly Adjusting Numbers
                  I have, as it happens.
                  • 6. Re: Random Decimal Numbers
                    Level 7
                    no comment.
                    > posts in nntp...
                    no i think this has always been the case but this is the 1st time i've noticed
                    a thread so completely changed....
                    • 7. Re: Randomly Adjusting Numbers
                      We could just see it as jjay@aus asking two separate questions. He/She is then the richer.
                      • 8. Re: Randomly Adjusting Numbers
                        jjay@aus Level 1
                        My Apologies to all those I have confused. I found the answer to my first questions literally minutes after submitting the posting (always the way), I originally came in to submit a reply to that nature and asking the next question found that the entire posting could be edited, and as no-one had responded at that time (had only been up a few minutes) I figured that must be the best way to minimise confusion. On the contrary.. clearly. Apologies again.
                        Again, apologies for the confusion (I know now), and thanks to those that help.
                        Cheers
