5 Replies Latest reply: Dec 23, 2013 1:39 PM by A/V Warrior RSS
    Footage is all white
    Red Planet Pictures Community Member
      So I installed the CC updates last week, and have a major problem with Premiere now. All footage of any kind I import shows up white. The thumbnails look fine in preview, but as soon as a clip is clicked on, opened, or hover scrubbed over, the footage turns white. Sometimes when I first start up Premiere it's a mess of giant code until I start moving the playhead around. I've attached screenshots of each instance, and notice that this in't even of actualy media, it's of the "media offline" placeholder. Literally every type of footage I import whatsoever does this. Meanwhile in CS6, everything works fine.
      I'm trying a full uninstall of all my CS6 apps now to see if it fixes it, and reinstalling Premiere CC. In the meantime though, wondering if anyone else has encountered this and has a fix? Thanks.
        • 1. Re: Footage is all white
          Bill Hunt CommunityMVP
          This could be a classic problem with your video driver.
          1. What OS are you running on?
          2. What video card do you have?
          3. What is the currently installed video driver?
          4. Is that the latest one available? If not, go to the nVidia, or AMD/ATI Web site, download and install the latest - test.
          Good luck, and if that does not fix things, you will have probably ruled out the video driver, as being the cause.
          • 2. Re: Footage is all white
            John T Smith CommunityMVP
            Adding to what Hunt asked... if you have nVidia
            How to determine your nVidia driver version
            Right click in any open area of the Windows desktop
            Select NVIDIA Control Panel from the popup window
            Select SYSTEM INFORMATION at the lower left corner
            Driver version should be the 1st line in Details
            I have a GTX285 using driver 296.10 and Win7
            (and I do NOT use the Cloud !!!)
            • 3. Re: Footage is all white
              Ok thanks guys, that wasn't it but I figured it out.
              It happens if you have Mercury Playback Engine GPU selected in a system with a non-supported GPU card! *sigh*
              It was particularly hard to figure out because it's an option under project settings, not general preferences, so I skipped over it several times in my troubleshooting. Gah, hours of reinstalls wasted for nothing! But at least now I know. Hope this helps someone else out there if they ever come across the same thing.
              • 4. Re: Footage is all white
                Thank you for reporting your success.
                Sorry about the uninstalls/reinstalls. I rather keep those in the back of the toolbox, but sometimes they DO fix thing, so are not to be discounted totally.
                • 5. Re: Footage is all white
                  A/V Warrior
                  What if you have the supported card and are still having this problem?
                  NVIDIA GeForce GTX 675MX 1024 MB
                  iMac 27" Late 2012
                  Cuda installed
                  I have to reset Premiere Pro and then start it back up to work only for a while and then it goes white again. I also have error compiling movie messages.
