dizzyjay3268 wrote:
> need some help. I have a field in a table that I use to
dynamically build a
> src for <a href> (let's call it "link_var") What
is retained in the link_var
> field is a string to append to a url links together
variables. An example of
> a db entry would be "ID=#ID#&test=#test#" In a
cfoutput of a query, how do i
> get the variable string to write correctly (giving me
the variables & values of
> each row).
> The method below is not working returns the string
literally and double
> escapes the last pound sign:
> <cfoutput query="test">
> <a href src="
http://localhost/test/index.cfm?#link_var#">test</a>
> </cfoutput>
> I may have a solution requiring breaking the field down
into lists and using
> evaluate() but i want to see if there is an easier way
> Any help is appreciated.
> DJ
not sure if this works or not - have not tested it - , but
try:
#de(link_vars)#
or
#evaluate(de(link_vars))#
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
