9 Replies Latest reply on Jul 11, 2013 6:59 PM by Carl Sun
    No programs listed in Extension Manager CC on Mac
    James Teague Level 1
      Hello,
      I am trying to install some extensions in Illustrator and Photoshop but none of the programs are listed in the Products column on the right hand side.  I have search the forums for workarounds and such and still no luck.  I have uninstalled all programs and re installed and still the same issue.  Any help would be greatly appreciated!!!!
      Mac 10.8.3
        • 1. Re: No programs listed in Extension Manager CC on Mac
          Carl Sun Level 4
          Did you install Illustrator CC and Photoshop CC in plugable external disk? Extension Manager can't support this case well.
          You can launch Adobe ExtendScript Toolkit CC or CS6, input "BridgeTalk.__diagnostics__;" (exclude double-quotes), then click "Debug->Run", you will get diagnostics information in Javascript Console window at the top right corner.
          Please check whether Illustrator CC or Photoshop CC have been listed under "Targets" section, and they has correct path and exename. If the path displayed is not consistent with the actual installation path, Extension Manager CC can't list the products because Extension Manager CC can't find the products in that path.
          • 2. Re: No programs listed in Extension Manager CC on Mac
            slayazz Level 1
            I have the same problem, but the above makes absolutely NO sense to me!
            • 3. Re: No programs listed in Extension Manager CC on Mac
              Carl Sun Level 4
              Do you mean the Javascript Console window output is all consistent with your application installation?
              • 4. Re: No programs listed in Extension Manager CC on Mac
                slayazz Level 1
                I didn'y understand, what you mean tbut after looking again i get:
                Result: BridgeTalk Diagnostics
                    Info:
                        Name = estoolkit-4.0
                        Status = PUMPING
                        Group = cs
                        Path = /Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app
                        Version = 2.0
                        Build = ES 4.5.5
                        Next serial number = 40
                        Logging: = OFF
                        Now = 10:02:46
                            Message Version = 2.05
                            Authentication = ON
                            Digest = ON
                    Thread: estoolkit-4.0#thread
                        Avg. pump interval = 74ms
                        Last pump = 57ms ago
                        Ping: 7
                            ECHO_REQUEST: ECHO_RESPONSE
                                Timeout = undefined
                                Handler = undefined
                            STATUS: PUMPING
                                Timeout = undefined
                                Handler = undefined
                            MAIN: MAIN
                                Timeout = undefined
                                Handler = installed
                            LAUNCHED: LAUNCHED
                                Timeout = undefined
                                Handler = installed
                            DIAGNOSTICS: DIAGNOSTICS
                                Timeout = undefined
                                Handler = installed
                            INFO: INFO
                                Timeout = undefined
                                Handler = installed
                            SETUPTIME: thread=1ms, left=27ms
                                Timeout = undefined
                                Handler = undefined
                    Instances: 3
                        estoolkit-4.0#dbg:
                                msg[10:02:46]: 00000035
                                    @BT>Version = 2.05
                                    Target = estoolkit-4.0#dbg
                                    Sender = estoolkit-4.0#dbg
                                    Sender-ID = localhost:mac826
                                    Timeout = 10:02:47
                                    Type = Ignore
                                    Response-Request = Timeout
                                    Headers = (no headers)
                                    Timestamp = 10:02:46
                                    Serial-Number = 35
                                    Received = undefined
                                    Result = undefined
                                    Error = undefined
                                    Body = (empty)
                            Incoming: 1
                            Outgoing: 0
                            Handler: 9
                                ExtendScript = for all messages
                                Error = for only msg #25
                                Error = for only msg #27
                                Error = for only msg #31
                                Result = for only msg #35
                                Error = for only msg #35
                                Timeout = for only msg #35
                                Result = for only msg #37
                                Error = for only msg #37
                        estoolkit-4.0#estk:
                                msg[10:02:46]: 00000037
                                    @BT>Version = 2.05
                                    Target = estoolkit-4.0#estk
                                    Timeout = 10:12:46
                                    Type = Debug
                                    Response-Request = Result Error
                                    Serial-Number = 37
                                    Result = undefined
                                    Error = undefined
                                    Body: 107 bytes
                                        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                            Incoming: 1
                            Outgoing: 0
                            Handler: 1
                        estoolkit-4.0: (main)
                            Incoming: 0
                            Outgoing: 0
                            Handler: 1
                    Targets: 3
                        Connector = PCD
                        Installed: 0
                        Running: 0
                            estoolkit-4.0: PUMPING
                                Group = cs
                                Display Name = ExtendScript Toolkit CC
                                MsgAuthentication = ON
                                MsgDigest = ON
                                ESTK = ON
                                Status = PUMPING
                                Info:
                                    Group = cs
                                    Version = 2.0
                                    Build = ES 4.5.5
                                    Next serial number = 43
                                    Logging: = OFF
                                    Now = 10:02:46
                                        Authentication = ON
                                        Digest = ON
                                    Last pump = 260ms ago
                                    Ping: 7
                                            Timeout = undefined
                                            Handler = undefined
                                        STATUS: PUMPING
                                            Timeout = undefined
                                            Handler = undefined
                                        MAIN: MAIN
                                            Timeout = undefined
                                            Handler = installed
                                        LAUNCHED: LAUNCHED
                                            Timeout = undefined
                                            Handler = installed
                                            Timeout = undefined
                                            Handler = installed
                                        INFO: INFO
                                            Timeout = undefined
                                            Handler = installed
                                            Timeout = undefined
                                            Handler = undefined
                                ExeName = ExtendScript Toolkit.app
                            exman-7.0:
                                Group = cs
                                Path = /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app
                                Display Name = Adobe Extension Manager CC
                                MsgDigest = ON
                                ESTK = OFF
                                BundleID = com.adobe.exman
                                Status = (not running)
                                ExeName = Adobe Extension Manager CC.app
                            photoshop-70.032:
                                Group = cs
                                Path = /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app
                                Display Name = Adobe Photoshop CC
                                MsgDigest = ON
                                ESTK = ON
                                BundleID = com.adobe.Photoshop
                                ExeName = Adobe Photoshop CC.app
                        Installed: 2
                        Running: 1
                        Groups: 140
                            cs3:
                                acrobat-8.0
                                aftereffects-8.0
                                soundbooth-1.0
                                bridge-2.0
                                contribute-4.5
                                devicecentral-1.0
                                dreamweaver-9.0
                                encore-3.0
                                estoolkit-2.0
                                fireworks-9.0
                                flash-9.0
                                illustrator-13.0
                                indesign-5.0
                                indesignserver-5.0
                                incopy-5.0
                                photoshop-10.0
                                premiere-3.0
                                premierepro-3.0
                                stockphotos-1.5
                                audition-3.0
                            cs4:
                                acrobat-9.0
                                aftereffects-9.0
                                soundbooth-2.0
                                bridge-3.0
                                contribute-5.0
                                devicecentral-2.0
                                dreamweaver-10.0
                                encore-4.0
                                estoolkit-3.0
                                fireworks-10.0
                                flash-10.0
                                illustrator-14.0
                                indesign-6.0
                                indesignserver-6.0
                                incopy-6.0
                                photoshop-11.*
                                premierepro-4.0
                                audition-4.0
                                ame-1.0
                                exman-2.0
                            cs5:
                                acrobat-9.0
                                aftereffects-10.0
                                soundbooth-3.0
                                bridge-4.0
                                contribute-6.0
                                devicecentral-3.0
                                dreamweaver-11.0
                                encore-5.0
                                estoolkit-3.5
                                fireworks-11.0
                                flash-11.0
                                illustrator-15.0
                                indesign-7.0
                                indesignserver-7.0
                                incopy-7.0
                                photoshop-12.*
                                premierepro-5.0
                                audition-5.0
                                ame-2.0
                                exman-3.0
                                flashbuilder-4.0
                                flashcatalyst-1.0
                            ts1:
                                captivate3-en_us
                                captivate3-fr_fr
                                captivate3-it_it
                                captivate3-ja_jp
                                captivate3-es_es
                                captivate3-de_de
                            ts2:
                                captivate-4.0
                            el2:
                                captivate-5.0
                            as1:
                                acrobat-10.0
                            ts3:
                                robohelp-9.0
                                framemaker-10.0
                            cs55:
                                aftereffects-10.5
                                audition-4.0
                                bridge-4.1
                                contribute-6.1
                                devicecentral-3.5
                                dreamweaver-11.5
                                encore-5.1
                                estoolkit-3.6
                                fireworks-11.1
                                flash-11.5
                                illustrator-15.1
                                indesign-7.5
                                indesignserver-7.5
                                incopy-7.5
                                photoshop-55.*
                                premierepro-5.5
                                ame-2.5
                                exman-5.5
                                flashbuilder-4.5
                                flashcatalyst-1.5
                                switchboard-2.0
                            el25:
                                captivate-5.5
                            cs60:
                                aftereffects-11.0
                                audition-5.0
                                bridge-5.*
                                contribute-6.88
                                devicecentral-4.0
                                dreamweaver-12.0
                                encore-6.0
                                estoolkit-3.8
                                fireworks-12.0
                                flash-12.0
                                illustrator-16.*
                                indesign-8.0
                                indesignserver-8.0
                                incopy-8.0
                                photoshop-60.*
                                premierepro-6.0
                                ame-6.0
                                exman-6.0
                                flashbuilder-4.52
                                switchboard-2.0
                                prelude-1.0
                                speedgrade-6.0
                            el60:
                                captivate-60.*
                            ts4:
                                robohelp-10.0
                                framemaker-11.0
                            cs70:
                                audition-6.0
                                bridge-6.*
                                dreamweaver-13.0
                                encore-7.0
                                fireworks-13.0
                                flash-13.0
                                illustrator-17.*
                                indesign-9.*
                                indesignserver-9.0
                                incopy-9.*
                                photoshop-70.*
                                premierepro-7.0
                                ame-7.0
                                exman-7.0
                                flashbuilder-5.0
                                prelude-2.0
                                estoolkit-4.0
                                aftereffects-12.0
                            el70:
                                captivate-70.*
                            cs70:
                                switchboard-3.*
                Thanks again
                • 5. Re: No programs listed in Extension Manager CC on Mac
                  Carl Sun Level 4
                  The output shows that you only installed one CC program which Extension Manager CC supports: Photoshop, and the installation path is /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app. Could you confirm that this path is correct?
                  • 6. Re: No programs listed in Extension Manager CC on Mac
                    slayazz Level 1
                    That path is correct.
                    But i have LOADS of apps installed, this shows a couple but I also have illustrator and indesign
                    • 7. Re: No programs listed in Extension Manager CC on Mac
                      No programs or paths show up in mine when I run BridgeTalk.__diagnostics__;
                          Info:
                              Status = PUMPING
                              Path
                              Version = 2.0
                              Build = ES 4.5.5
                              Next serial number = 18
                              Logging: = OFF
                              Now = 05:57:57
                                  Authentication = ON
                                  Digest = ON
                              Last pump = 40ms ago
                              Ping: 7
                                      Timeout = undefined
                                      Handler = undefined
                                  STATUS: PUMPING
                                      Timeout = undefined
                                      Handler = undefined
                                  MAIN: MAIN
                                      Timeout = undefined
                                      Handler = installed
                                  LAUNCHED: LAUNCHED
                                      Timeout = undefined
                                      Handler = installed
                                      Timeout = undefined
                                      Handler = installed
                                  INFO: INFO
                                      Timeout = undefined
                                      Handler = installed
                                  SETUPTIME: thread=0ms, left=1ms
                                      Timeout = undefined
                                      Handler = undefined
                          Instances: 3
                              estoolkit-4.0#dbg:
                                      msg[05:57:57]: 00000013
                                          @BT>Version = 2.05
                                          Sender-ID = localhost:mac57349
                                          Timeout = 05:57:58
                                          Type = Ignore
                                          Timestamp = 05:57:57
                                          Serial-Number = 13
                                          Result = undefined
                                          Error = undefined
                                          Body = (empty)
                                  Incoming: 1
                                  Outgoing: 0
                                  Handler: 9
                                      Error = for only msg #5
                                      Error = for only msg #9
                                      Result = for only msg #13
                                      Error = for only msg #13
                                      Timeout = for only msg #13
                                      Result = for only msg #15
                                      Error = for only msg #15
                              estoolkit-4.0#estk:
                                      msg[05:57:57]: 00000015
                                          @BT>Version = 2.05
                                          Timeout = 06:07:57
                                          Type = Debug
                                          Serial-Number = 15
                                          Result = undefined
                                          Error = undefined
                                          Body: 107 bytes
                                  Incoming: 1
                                  Outgoing: 0
                                  Handler: 1
                                  Incoming: 0
                                  Outgoing: 0
                                  Handler: 1
                      • 8. Re: No programs listed in Extension Manager CC on Mac
                        Carl Sun Level 4
                        Normally CC applications will write the installation information to the PCD during installation. Extension Manager CC will read PCD to know which apps are installed and where they are installed via BridgeTalk. In your case Illustrator, InDesign and Dreamweaver didn't write information to PCD so Extension Manager CC can't list them. This is issues of their installers.
                        I can't figure out why PS is not listed by Extension Manager CC.
                        • 9. Re: No programs listed in Extension Manager CC on Mac
                          Carl Sun Level 4
                          You have to ask in forum of those apps why they didn't write installation information to PCD.
