7 Replies Latest reply: Aug 14, 2013 4:44 PM by ratko RSS
    Can anyone assist with a report that extracts the External ID field in the CRM
    Greg.Tomkins Community Member
      I have a membership system where the client has imported 3600+ records some of which had the Eternal ID ('Your ID field on the import file) set and some don't.
      The trouble is I need to update all the CRM records and can't import the changes as I don't know what the original external id value is. Business Catalyst support advised that they can't include this field in any report (don't get me started on that...) and I am now desperately in need of some way to get that data which is on the file and is critical to any further updates via the import files. I would delete all the records and start again except that there is no bulk delete option in BC CRM - yes you can do it in products but not CRM or Web Apps...!!! The only option available in BC is to delete one screen list at a time but then I have the issue that this matter does not relate to all CRM records - only those whio are members of a secure zone.
      My need is urgent so any assistance free or otherwise would be approeciated and the solution needs to be one that enables me to run such an export on an irregular basis.
        • 1. Re: Can anyone assist with a report that extracts the External ID field in the CRM
          thetrickster888 Community Member
          I don't have any code to show you but one possible solution is to use BC's API to do this.  I know there's a CRM API where you can get at the CRM data so maybe you can build an API integration with PHP or another scripting language to connect with BC's CRM API, pull your contact data and generate a comma separated list (CSV) that you can then save.
          If you do need this urgently and don't want to wait I know you could probably pay to have a BC developer do it for you who have experience with the API like http://twoblokeswithapostie.com or http://simpleflame.com
          There might be another way to generate this kind of report but I'm not familiar with it.  Maybe someone could post about how to delete the CRM entries in bulk which would help you or if there's another, non-API way to do this.
          Best of luck.
          • 2. Re: Can anyone assist with a report that extracts the External ID field in the CRM
            OK... thanks to those who offered assistance and I now feel somewhat a goose but then not altogether.
            BC in its usual style of help documentation, are not at all clear in their explanation of how the Unique Id (which is actually the field 'External ID' in th CRM under the Misc section). Below is the description extracted from the import template
            • The above columns represent all the available columns that can be imported using the standard contact import feature. Columns do not need to contain information but they must be present on the page, especially if a proceeding column contains information.
            • If your organization uses its own unique identification number to differentiate between customers then use the Your ID column. If a value is present in this column then it will serve as the unique identifier. This means if the contact was previously imported and it is being re-imported then his or her details are updated, otherwise a new contact record is created regardless of whether a similar contact already exists in the system.
            • If the Your ID column is not used then contacts are generally identified by their email address. The minimum requirement to import a contact into the system is that either Your ID, Email Address, Fullname, firstname or last name must be present on a single row. If these values are missing the the row is not imported and the import will move to the next row.
            • If you don't provide Your ID nor an email address and only a name then the contact is added each time regardless of whether a similar one already exists in the system.
            Now my understanding is that if you have used the Your Id then being the unique identifier and as such all future imports would have to use that... Well no this isn't the case at all.
            If you import a set of records that all use the Your Id you can simply update those same records with just the email address - you don't need to Your Id or External Id at all!!!  So what is the purpose of this field at all? I have no idea myself as it can't be reported, it can't be exported, it can't be referenced - in fact the only way you will ever see it is to open the CRM record and expand the Misc details and buried at the bottom you will find it. Now that is what I call an undocumented feature !
            So end of it all is - my concerns all proved baseless and you don't have to concern yourself with the External / Your Id field no matter what the customer does.
            My advice - forget this field exists and don't bother trying to use it unless you might happen to be interfacing into some 3rd party system through PAI's as this seems to be the only use I can think of for it.
            • 3. Re: Can anyone assist with a report that extracts the External ID field in the CRM
              Nice find... I think I remember finding that out the hard way once too... thanks for reminding me.  I think External ID was really added so that if your client had some old way to keep/manage their records from an old system you can use that field to include it in BC but since there's no reporting functionality, what's the point?  Are you sure that External ID does not matter at all? Maybe if there's no external id then email address becomes the delineating field and if there is an external id then External ID becomes the delineating field.
              • 4. Re: Can anyone assist with a report that extracts the External ID field in the CRM
                As a postscript... if you are also dealing with usernames on your CRM  records for secure zone access there is another catch...
                All is fine if you users have email addresses but yes I have a client who has a large number of members who need access but don't have email addresses...
                When you import these the username becomes the unique identifier - yes you can add 2 contact records with teh same name, no email, no External ID but with different usernames.
                Your problem occurs if you try to do an import update on such records - if you use the same username the import will fail (and yes 1 record error message at a time on the import so check your data first).
                So you can't update a CRM record that has no email address using the same username - trouble is if you provide a new username you actually create a NEW CRM record and yu don't update the original record (which makes sense).
                This is where the External / Your ID does come in handy - if you use this you can update the original record including changing the username - trouble now is - you have to know what the External / Your Id is and use this in any future updates which of course you can't find out unless yuo keep some external register.
                So the learning here is - try and avid setting up CRM contact redords for accessing secure zones where the contact has no email address.
                If this has all confused yu - don't feel too bad... you could have shown yur ignorance of all this as I have publcily here... hope this helps others
                • 5. Re: Can anyone assist with a report that extracts the External ID field in the CRM
                  ratko
                  One more important detail. External ID will serve as a primary key if you have or don't have an email address present but that doesn't mean that you will be able to edit the email address through the import. You can't. Ever. Even if you didn't enter email to beging with and your email field is empty. IT WILL NOT LET YOU ADD OR EDIT EMAIL, PERIOD. This is terrible! I have hundreds of records with emails a client wants to change for all their contacts. Now I have to create hundreds of email forwards. Rediculous.
                  • 6. Re: Can anyone assist with a report that extracts the External ID field in the CRM
                    Your only choice would be to delete those - in another post (sorry can't remember where) it was suggested thatthe only way to dlete CRM records is to apply an update with the records you want to delete and to then reverse the import which in fact delets the CRM records or soemthing to that effect. Convoluted and crazy solution I know and I just wish BC would sort out this matter of CRM updates cleanly
                    • 7. Re: Can anyone assist with a report that extracts the External ID field in the CRM
                      ratko Community Member
                      That woudl work if I didn't have to preserve all the records of all the contacts. But the fact they want to keep all records and just change email addresses on all of them leaves me with a choice of manually changing each one or redirecting emails externally. The second choice is faster but has its ownset of problems. So the best woudl be to do the grunt work and plug one after another for a few straight hours. Thanks BC!
