3 Replies Latest reply on Jul 11, 2013 10:59 PM by c.pfaffenbichler
    Color Authoring
    mangalarajiv Level 1
      I tried using match color & replace color, how do i achieve the target color through scripting?
      for example: take any of two apparel images and start try color matching through scripting.
      thanks,
      rajiv.s
        • 1. Re: Color Authoring
          c.pfaffenbichler Level 9
          I doubt that automating this will produce good results.
          I consider Replace Color unfit for professional work and Match Color of fairly little use in general.
          Have you been able to produce Action Manager code for the two operations with ScriptingListener.plugin?
          Could you please post examplary image pair/s and the results you want to achieve?
          • 2. Re: Color Authoring
            I have attached two images, source and target image. Need to change the source image (Black) to Target image color.
            Please let me know
            thanks for your help
            • 3. Re: Color Authoring
              Basically I think fully automating this task is not achieveable with satisfactory results at current.
              Recoloring black items is usually a bad idea to begin with (for example because of the fringe issue and having to create color content from a limited luminance range).
              Also the Selection of the region would almost cerainly take a lot of manual intervention.
              Edit: With »fringe issue« I mean the sometime necessity to decontaminate both foreground (in this case the shirt) and background (the grey background but also the jeans and regions of skin and hair that touch the shirt) to avoid irritating effects along the edge if the mask has any softness.
