1 Reply Latest reply on Oct 9, 2007 9:12 AM by bigdyce504
    FLV Player with media list
    bigdyce504
      I downloaded this tutorial but I can't get it to work.
      Here's what it looks like so far:
      http://www.neworleansblack.com/tv_test.html
      I'm pretty sure I followed the directions to the tee. It is supposed to load a media list from an external xml file, autoPlay the first item in the list and play the rest sequentially. For some reason it's only loading the first video and not automatically. I'm thinking it's either an actionscript issue or a xml issue. I'm posting both in hopes that one of the geniuses here will have some insight on this.
      Actionscript:
      quote:
      //Default gradient fill
      var gradientDefault:Object = new Object;
      gradientDefault.fillType = "linear";
      gradientDefault.colors = [0x000000, 0x333333];
      gradientDefault.alphas = [75, 75];
      gradientDefault.ratios = [0, 255];
      gradientDefault.matrix = new flash.geom.Matrix();
      gradientDefault.matrix.createGradientBox(100, 50, (Math.PI * 3 / 2), 0, 0);
      myList.itemDefaultStyle.fillGradient = gradientDefault;
      //Over gradient fill
      var gradientOver:Object = new Object;
      gradientOver.fillType = "linear";
      gradientOver.colors = [0x000000, 0x333333];
      gradientOver.alphas = [85, 85];
      gradientOver.ratios = [0, 255];
      gradientOver.matrix = new flash.geom.Matrix();
      gradientOver.matrix.createGradientBox(100, 50, (Math.PI * 3 / 2), 0, 0);
      myList.itemOverStyle.fillGradient = gradientOver;
      //Selected gradient fill
      var gradientSelected:Object = new Object;
      gradientSelected.fillType = "linear";
      gradientSelected.colors = [0x000000, 0x333333];
      gradientSelected.alphas = [95, 95];
      gradientSelected.ratios = [0, 255];
      gradientSelected.matrix = new flash.geom.Matrix();
      gradientSelected.matrix.createGradientBox(100, 50, (Math.PI * 3 / 2), 0, 0);
      myList.itemSelectedStyle.fillGradient = gradientSelected;
      //Play the first item when loading is complete
      myList.addEventListener("CONTENT_LOAD_COMPLETE", this);
      function CONTENT_LOAD_COMPLETE(evnt:Object) {
      //Select first item in the list
      myList.selectItemNum(0);
      //Get and play the first item in the list
      var item:Object = myList.getItemNum(0);
      myPlayer.autoSize = false;
      myPlayer.contentPath = item.data;
      //Select next item when play completes
      var listenerObject:Object = new Object();
      listenerObject.complete = function(eventObject:Object):Void {
      myList.selectNextItem();
      //Get and play the next item
      var item = myList.getSelectedItem();
      myPlayer.addEventListener("complete", listenerObject);
      //Play an item when it is clicked.
      myList.addEventListener("ITEM_ON_RELEASE", this);
      function ITEM_ON_RELEASE(evnt:Object) {
      myPlayer.contentPath = evnt.target.data;
      XML:
      quote:
      <?xml version="1.0"?>
      <content>
      <item>
      <title>Mychal Bell Relased from Prison</title>
      <description></description>
      <thumbnailPath></thumbnailPath>
      <data> http://www.neworleansblack.com/nobtv/MychalBellReleased.flv</data>
      </item>
      <item>
      <title>Single Black Female</title>
      <data> http://www.neworleansblack.com/nobtv/SingleAfricanAmericanWomen.flv</data>
      </item>
      <item>
      <title>Soulja Boy How To</title>
      <description>Learn how the newest dance sweeping the country.</description>
      <data> http://www.neworleansblack.com/nobtv/SouljaBoy_instructionalvideo.flv</data>
      </item>
      <item>
      <title>Health in New Orleans</title>
      <data> http://www.neworleansblack.com/nobtv/NewOrleansHealth.flv</data>
      </item>
      </content>
      I can also upload the .fla file if needed.
        • 1. Re: FLV Player with media list
          bigdyce504 Level 1
          OK, it turns out that the thumbnail is required for each item, so that's why the xml list stopped loading. But I still can't get it to autoPlay. I made sure that autoPlay was set to "true" in the parameters of the list, I didn't see a way to set it for the player. Does it matter? Any thoughts?
          Also, is there a way to generate the thumbnails automatically?
          And, it's taking hours for the player to recognize changes in the XML list after it's been updated. Any thoughts?
