3 Replies Latest reply: Jul 3, 2013 6:40 AM by Andreasp123 RSS
    Adobe Packager Admin installer package fails
    Andreasp123 Community Member
      Hi
      I have made 2 packages with the Creative Cloud Packager, one with Acrobat 32bit (Package 1) and one with PS,AI, IN 64 bit (package 2). I could not include Acrobat because it’s a 32 bit application...
      If I uninstall all CS5 apps no one of my install packages work. The CC cleaner tool fix that initial problem and I’m able to install package 2. But when that is installed Package 1 will not install and Creative Cloud Desktop app failing when it tries to update itself.
      If I Install Acrobat from CC desktop that installer runs and completes ok.
      I have tried a couple of machines and they have same problem.
      One thing that seem to make a lot of trouble are language setting. We use Windows 7 64 bit English but with Swedish keyboard layout. I made the packages with English (International) and the CC Desktop often has English (North America) as default. If I install English (International) apps and CC desktop is set to North America, it will not find the installed apps until I change to International there as well.
      Is there no way to Download CC desktop only and Push it to clients and set the language? I only have the “Install” option in the browser, no download option.
      I don’t find any useful logs, event viewer just tells me the following:
      Beginning a Windows Installer transaction: Z:\Adobe\CC_AcroPro\Build\CC_AcroPro.msi. Client Process Id: 15196.
      Ending a Windows Installer transaction: Z:\Adobe\CC_AcroPro\Build\CC_AcroPro.msi. Client Process Id: 15196.
      Product: CC_AcroPro -- Installation operation failed. (EventID 11708)
      Windows 7 64 bit sp1.
      Firewall, off
      AW, off
      All users are local admin
        • 1. Re: Adobe Packager Admin installer package fails
          Jeff A Wright Employee Hosts
          Moving this discussion to the Creative Suite Enterprise Deployment forum.
          • 2. Re: Adobe Packager Admin installer package fails
            Thank you
            I dont see this forum, Adobe Community > Downloading, Installing, Setting Up, is where it ends for me. No sub sections.
            I have no idea how you got to Adobe Community > Downloading, Installing, Setting Up > Creative Suite Enterprise Deployment > Discussions, spent 10 min klicking around in the forum but cant find my way here. Bookmarked!
            • 3. Re: Adobe Packager Admin installer package fails
              I will just add the log.
              There are a lot of "Failed to find Node".
              and lines with dubble backslashes
              File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\P7\P7.pimx' does not exist
              File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\P6\P6.pimx' does not exist
              It exits rather quick, so I think the problem is all the pre stuff. But I cant narrow it down to a specific thing..
              07/03/13 11:20:05:787 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 15804 | Build Version - 1.1.0.27
              07/03/13 11:20:05:787 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 15804 | Logging Level verbosity Set  to 4
              07/03/13 11:20:05:787 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 15804 | Executing immediate custom action for install mode.
              07/03/13 11:20:05:788 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 15804 | The CustomActionData string is : mode=install;sourceDir=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\;installDir=;or igDB=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\CC_AcroPro.msi
              07/03/13 11:20:05:788 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 15804 | Successfully executed the immediate custom action for install mode .
              07/03/13 11:20:08:657 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Build Version - 1.1.0.27
              07/03/13 11:20:08:657 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Logging Level verbosity Set  to 4
              07/03/13 11:20:08:657 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Executing the deferred custom action.
              07/03/13 11:20:08:664 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Obtained the following as CustomActionData
              07/03/13 11:20:08:664 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | mode=install;sourceDir=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\;installDir=;or igDB=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\CC_AcroPro.msi
              07/03/13 11:20:08:665 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | mode=install;sourceDir=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\;installDir=;or igDB=\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\CC_AcroPro.msi
              07/03/13 11:20:08:665 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Original database path is : \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\CC_AcroPro.msi
              07/03/13 11:20:08:671 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | OptionXML saved at location :: C:\Users\ANDREA~1.PET\AppData\Local\Temp\{64136D00-FD35-462E-B6BF-82E6A6D132E0}\\{94568A4 E-7D88-4748-8D37-6D01380F12C4}
              07/03/13 11:20:08:684 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Build Version - 1.1.0.27
              07/03/13 11:20:08:684 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Logging Level verbosity Set  to 4
              07/03/13 11:20:08:684 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Initializing Custom Action Data from parameters
              07/03/13 11:20:08:684 | [INFO] |  | ASU | DeploymentManager | Utilities |  |  | 17600 | Folder does not exist
              07/03/13 11:20:08:684 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Provisioning Tool path is (C:\Users\ANDREA~1.PET\AppData\Local\Temp\{64136D00-FD35-462E-B6BF-82E6A6D132E0}\\{42C245 45-2FDC-4F67-8D50-CD0CBC65FFB4}).
              07/03/13 11:20:08:687 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Starting to run the custom action for install mode
              07/03/13 11:20:08:687 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | STEP 1: Starting to parse Option XML.
              07/03/13 11:20:08:689 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Self-Update BootStrapper Relative Path doesn't exist.
              07/03/13 11:20:08:689 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | No of updates found (0).
              07/03/13 11:20:08:690 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Number of Medias found = 1
              07/03/13 11:20:08:690 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Deployment Manager is running in Install Mode.
              07/03/13 11:20:08:693 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Deployment XML created at path :: C:\Users\ANDREA~1.PET\AppData\Local\Temp\{3213A49E-6B67-4FA3-BB3F-84B70F662CB0}\\{6BE063E 1-D3DB-45C5-9F60-C15C65F08BC9}
              07/03/13 11:20:08:695 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Override XML created at path :: C:\Users\ANDREA~1.PET\AppData\Local\Temp\{3213A49E-6B67-4FA3-BB3F-84B70F662CB0}\\{0898CCF 1-BBB1-422A-97E4-93F13713F90B}
              07/03/13 11:20:08:705 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | STEP 2: Starting to launch ASU AAM.
              07/03/13 11:20:08:705 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Bootstrapper launch location is :: \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\Set-up.dat
              07/03/13 11:20:08:988 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | \Users\ANDREA~1.PET\AppData\Local\Temp\PDApp.log
              07/03/13 11:20:08:988 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:08:988 | [INFO] |  | ASU | Setup | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMConfig.xml' does not exist
              07/03/13 11:20:08:990 | [INFO] |  | ASU | Setup |  |  |  | 17068 | Event Guid generated is: 'f7eae6ba-adc1-4253-83a1-1001c448cbe7'
              07/03/13 11:20:08:991 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Start Adobe Setup
              07/03/13 11:20:08:991 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | TimeLog: Bootstrapper Start
              07/03/13 11:20:08:991 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | TimeLog: Start initial checks
              07/03/13 11:20:08:991 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Action specified - "install"
              07/03/13 11:20:08:998 | [INFO] |  | ASU | Setup |  |  |  | 12024 | Event with guid 'f7eae6ba-adc1-4253-83a1-1001c448cbe7' is being sent
              07/03/13 11:20:09:009 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - No default proxy present on the user machine
              07/03/13 11:20:09:009 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - proxy Url is
              07/03/13 11:20:09:021 | [INFO] |  | ASU | Setup | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:022 | [WARN] |  | ASU | Setup | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:022 | [WARN] |  | ASU | Setup | Setup |  |  | 17068 | Reboot is pending from earlier installation.
              07/03/13 11:20:09:112 | [INFO] |  | ASU | Setup | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:116 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
              07/03/13 11:20:09:119 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:09:125 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
              07/03/13 11:20:09:125 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Users\ANDREA~1.PET\AppData\Local\Temp\\asuap.txt' does not exist
              07/03/13 11:20:09:125 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
              07/03/13 11:20:09:125 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:09:125 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | CREATE PIM Instance ...
              07/03/13 11:20:09:126 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
              07/03/13 11:20:09:134 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | trying to createOrUpdatePIMDbSchema.
              07/03/13 11:20:09:140 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version on machine 2.
              07/03/13 11:20:09:140 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version to install 2.
              07/03/13 11:20:09:140 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM DB Schema is up to date. Current schema version is 2.
              07/03/13 11:20:09:140 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM Database is Up To Date.
              07/03/13 11:20:09:140 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Updater Inventory location:\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\resources\updaterinventor y.dll
              07/03/13 11:20:09:234 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Acquired System level ACF lock ...
              07/03/13 11:20:09:234 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
              07/03/13 11:20:09:234 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:09:234 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\pim.db-journal' does not exist
              07/03/13 11:20:09:234 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | CREATE PIM Instance ...
              07/03/13 11:20:09:235 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\pim.db-journal' does not exist
              07/03/13 11:20:09:235 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | trying to createOrUpdatePIMDbSchema.
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version on machine 2.
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version to install 2.
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM DB Schema is up to date. Current schema version is 2.
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM Database is Up To Date.
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Updater Inventory location:\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\resources\updaterinventor y.dll
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Acquired System level ACCC lock ...
              07/03/13 11:20:09:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:237 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:238 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:262 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:262 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:263 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id E503D1A9-30F3-4492-A0D7-5691E1693A22 is already installed
              07/03/13 11:20:09:298 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:298 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:299 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 35FD84CA-6E38-437D-91B3-8EF2162020C9 is already installed
              07/03/13 11:20:09:317 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:317 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:318 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 1F7ECA8B-CC65-42B2-BB0D-F7B1ABB44A2D is already installed
              07/03/13 11:20:09:332 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:332 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:333 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 99477136-88AD-496B-9551-BAE72699A32C is already installed
              07/03/13 11:20:09:361 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:361 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:362 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id AED493F4-D153-42DE-9020-4C0583812AD2 is already installed
              07/03/13 11:20:09:407 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:407 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:408 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
              07/03/13 11:20:09:454 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:455 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:456 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 2785F982-E793-4A7F-9A97-D929CF269DA8 is already installed
              07/03/13 11:20:09:481 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:482 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:483 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:484 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id D70795E5-4F23-4FCA-AB98-CA1297ABA8A1 is already installed
              07/03/13 11:20:09:484 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:494 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:494 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:495 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 478DBDF4-F26C-4E36-A512-EC79A4CDD61E is already installed
              07/03/13 11:20:09:509 | [INFO] |  | ASU | Setup |  |  |  | 13392 | HTTP Request Status code 200.
              07/03/13 11:20:09:510 | [INFO] |  | ASU | Setup |  |  |  | 12024 | The http request returned HTTP_Status:0 HttpCommunicator error:0
              07/03/13 11:20:09:514 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 30250774
              07/03/13 11:20:09:515 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | The size required to install AAM on your machine would be 30250774
              07/03/13 11:20:09:515 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:515 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:516 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:516 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Matching skip string found skipServiceManager.
              07/03/13 11:20:09:517 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:531 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:531 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:531 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:532 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 6377B77D-A58A-4322-887D-0E6746A9BCC9 is already installed
              07/03/13 11:20:09:532 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:540 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:540 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:541 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:541 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 13F444D5-E50B-49DF-B0C0-6B48123508C9 is already installed
              07/03/13 11:20:09:546 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:556 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:557 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:557 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:557 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 75A8A09F-2C3C-4713-9208-DE3A2B1C17D6 is already installed
              07/03/13 11:20:09:566 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:566 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:566 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:567 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id DEC2AAB1-D4E8-453D-9BC1-6258BF428BBD is already installed
              07/03/13 11:20:09:567 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:586 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:586 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:586 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:587 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id F2E5E4DB-6511-4BDB-B68D-21DEFD2645B8 is already installed
              07/03/13 11:20:09:593 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:611 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:611 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:611 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:611 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 0D2BE91D-B682-401D-AF41-58B85495620A is already installed
              07/03/13 11:20:09:621 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:621 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:622 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:622 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id F25639A1-9166-42CF-98C1-7D56F5E7507C is already installed
              07/03/13 11:20:09:630 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:630 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:631 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:633 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id CDAB818D-E642-4023-9055-3A695E20D980 is already installed
              07/03/13 11:20:09:645 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:654 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:654 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:654 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:655 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:655 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 07C49633-BF40-4619-830E-C2B1D3F8E864 is already installed
              07/03/13 11:20:09:674 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:682 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:682 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:682 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:683 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:683 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 84FABF52-8AE2-4BAF-AD11-9843573BFC20 is already installed
              07/03/13 11:20:09:699 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:699 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:699 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:700 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:700 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 892CACE4-5BD7-45F5-8713-7A1FF6E8B550 is already installed
              07/03/13 11:20:09:715 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:726 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:726 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:727 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:727 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 7B3E7943-BC11-4137-8230-728C2D46BDD4 is already installed
              07/03/13 11:20:09:731 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:741 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:741 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:741 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:742 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 765C1147-B05D-4BF7-BE49-0CD62BED1911 is already installed
              07/03/13 11:20:09:742 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:769 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:769 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:769 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:770 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id FE496F46-35AA-4D40-BACC-BD74D3D5360D is already installed
              07/03/13 11:20:09:774 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:774 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 62738370
              07/03/13 11:20:09:774 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | The size required to install ACCC on your machine would be 62738370
              07/03/13 11:20:09:774 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | The size required to install complete ACCC on your machine would be 92989144
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIMSqlite closeDB status 0
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | FREE PIM Instance ...
              07/03/13 11:20:09:775 | [INFO] |  | ASU | Setup | Utilities |  |  | 17068 | Semaphore is not locked
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\pim.db-journal' does not exist
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Users\ANDREA~1.PET\AppData\Local\Temp\\asuap.txt' does not exist
              07/03/13 11:20:09:775 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | CREATE PIM Instance ...
              07/03/13 11:20:09:776 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\pim.db-journal' does not exist
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | trying to createOrUpdatePIMDbSchema.
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version on machine 2.
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version to install 2.
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM DB Schema is up to date. Current schema version is 2.
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM Database is Up To Date.
              07/03/13 11:20:09:777 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Updater Inventory location:\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\resources\updaterinventor y.dll
              07/03/13 11:20:09:790 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Acquired System level ACF lock ...
              07/03/13 11:20:09:790 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | TimeLog: End initial checks
              07/03/13 11:20:09:790 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | TimeLog: Begin Installing
              07/03/13 11:20:09:790 | [INFO] |  | ASU | Setup | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:791 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:791 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:792 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Skip properties not defined for current node
              07/03/13 11:20:09:796 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:796 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:797 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id E503D1A9-30F3-4492-A0D7-5691E1693A22 is already installed
              07/03/13 11:20:09:804 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:804 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:804 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 35FD84CA-6E38-437D-91B3-8EF2162020C9 is already installed
              07/03/13 11:20:09:809 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:809 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:810 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 1F7ECA8B-CC65-42B2-BB0D-F7B1ABB44A2D is already installed
              07/03/13 11:20:09:812 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:812 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:813 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 99477136-88AD-496B-9551-BAE72699A32C is already installed
              07/03/13 11:20:09:817 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:817 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:818 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id AED493F4-D153-42DE-9020-4C0583812AD2 is already installed
              07/03/13 11:20:09:825 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:825 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:825 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
              07/03/13 11:20:09:833 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:834 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:834 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 2785F982-E793-4A7F-9A97-D929CF269DA8 is already installed
              07/03/13 11:20:09:841 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:841 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:09:842 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:842 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id D70795E5-4F23-4FCA-AB98-CA1297ABA8A1 is already installed
              07/03/13 11:20:09:843 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:844 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:844 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 478DBDF4-F26C-4E36-A512-EC79A4CDD61E is already installed
              07/03/13 11:20:09:850 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 30250774
              07/03/13 11:20:09:850 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Executing Adobe Genuine Validation for all the AAM packages
              07/03/13 11:20:09:850 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\core\PDApp.pimx'
              07/03/13 11:20:09:852 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:853 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:867 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\core\PDApp.pima'
              07/03/13 11:20:09:941 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\D6\D6.pimx'
              07/03/13 11:20:09:943 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:09:943 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:09:966 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\D6\D6.pima'
              07/03/13 11:20:10:041 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DECore\DECore.pimx'
              07/03/13 11:20:10:043 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:043 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:050 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DECore\DECore.pima'
              07/03/13 11:20:10:121 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DWA\DWA.pimx'
              07/03/13 11:20:10:122 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:122 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:129 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DWA\DWA.pima'
              07/03/13 11:20:10:208 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P6\P6.pimx'
              07/03/13 11:20:10:209 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:209 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:236 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P6\P6.pima'
              07/03/13 11:20:10:413 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\LWA\LWA.pimx'
              07/03/13 11:20:10:414 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:415 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:422 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\LWA\LWA.pima'
              07/03/13 11:20:10:544 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\UWA\UWA.pimx'
              07/03/13 11:20:10:546 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:547 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:554 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\UWA\UWA.pima'
              07/03/13 11:20:10:690 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\CCM\CCM.pimx'
              07/03/13 11:20:10:693 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:693 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:10:693 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:701 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\CCM\CCM.pima'
              07/03/13 11:20:10:705 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P7\P7.pimx'
              07/03/13 11:20:10:706 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:706 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:740 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Validating package file: '\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P7\P7.pima'
              07/03/13 11:20:10:948 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Adobe Genuine Validation PASSED for all the AAM packages
              07/03/13 11:20:10:948 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\core\PDApp.pimx
              07/03/13 11:20:10:951 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:10:952 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:10:952 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id E503D1A9-30F3-4492-A0D7-5691E1693A22 is already installed
              07/03/13 11:20:10:961 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:10:962 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:10:962 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:11:068 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:11:069 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:11:139 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:11:139 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:11:144 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:11:144 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:11:144 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:11:147 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:11:147 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:11:163 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:11:164 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:087 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\PDApp.pimx' does not exist
              07/03/13 11:20:12:226 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:226 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:229 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:229 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:230 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\core\PDApp.pimx.
              07/03/13 11:20:12:230 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /core/
              07/03/13 11:20:12:289 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\D6\D6.pimx
              07/03/13 11:20:12:291 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:291 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:291 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 35FD84CA-6E38-437D-91B3-8EF2162020C9 is already installed
              07/03/13 11:20:12:295 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:12:296 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:12:296 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:12:320 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:12:320 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:12:353 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:12:353 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:356 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:12:356 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:356 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:12:358 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:358 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:369 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:12:369 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:606 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\D6\D6.pimx' does not exist
              07/03/13 11:20:12:662 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:662 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:664 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:664 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:664 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\D6\D6.pimx.
              07/03/13 11:20:12:664 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /D6/
              07/03/13 11:20:12:697 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DECore\DECore.pimx
              07/03/13 11:20:12:699 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:699 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:700 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 1F7ECA8B-CC65-42B2-BB0D-F7B1ABB44A2D is already installed
              07/03/13 11:20:12:703 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:12:704 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:12:704 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:12:720 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:12:720 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:12:751 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:12:751 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:753 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:753 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:12:754 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:754 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:12:755 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:12:756 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:12:766 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:12:766 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:551 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\DECore\DECore.pimx' does not exist
              07/03/13 11:20:13:588 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:588 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:589 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:589 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:590 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DECore\DECore.pimx.
              07/03/13 11:20:13:590 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /DECore/
              07/03/13 11:20:13:615 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DWA\DWA.pimx
              07/03/13 11:20:13:616 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:616 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:616 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 99477136-88AD-496B-9551-BAE72699A32C is already installed
              07/03/13 11:20:13:620 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:13:620 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:13:620 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:13:632 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:13:632 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:13:650 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:13:650 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:652 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:13:652 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:652 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:13:653 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:653 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:668 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:13:668 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:670 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:958 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\DWA\DWA.pimx' does not exist
              07/03/13 11:20:13:985 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:985 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:986 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:13:986 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:13:986 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\DWA\DWA.pimx.
              07/03/13 11:20:13:986 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /DWA/
              07/03/13 11:20:14:012 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P6\P6.pimx
              07/03/13 11:20:14:013 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:014 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:014 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id AED493F4-D153-42DE-9020-4C0583812AD2 is already installed
              07/03/13 11:20:14:017 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:14:017 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:14:017 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:14:030 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:14:030 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:14:057 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:14:057 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:060 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:14:060 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:060 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:14:062 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:062 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:072 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:14:073 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:610 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\P6\P6.pimx' does not exist
              07/03/13 11:20:14:642 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:642 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:644 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:644 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:644 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P6\P6.pimx.
              07/03/13 11:20:14:644 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /P6/
              07/03/13 11:20:14:754 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\LWA\LWA.pimx
              07/03/13 11:20:14:756 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:756 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:756 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is already installed
              07/03/13 11:20:14:758 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:14:758 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:14:759 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:14:770 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:14:770 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:14:787 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:14:787 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:789 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:14:789 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:789 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:14:791 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:14:791 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:803 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:14:803 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:14:804 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:259 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\LWA\LWA.pimx' does not exist
              07/03/13 11:20:15:296 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:15:296 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:297 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:15:297 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:297 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\LWA\LWA.pimx.
              07/03/13 11:20:15:297 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /LWA/
              07/03/13 11:20:15:392 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\UWA\UWA.pimx
              07/03/13 11:20:15:394 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:15:394 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:395 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 2785F982-E793-4A7F-9A97-D929CF269DA8 is already installed
              07/03/13 11:20:15:397 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:15:398 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:15:398 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:15:415 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:15:416 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:15:472 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:15:472 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:476 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:15:476 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:476 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:15:479 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:15:479 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:514 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:15:515 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:15:989 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\UWA.pimx' does not exist
              07/03/13 11:20:16:018 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:018 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:021 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:021 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:021 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\UWA\UWA.pimx.
              07/03/13 11:20:16:021 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /UWA/
              07/03/13 11:20:16:047 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\CCM\CCM.pimx
              07/03/13 11:20:16:050 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:050 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:051 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:052 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id D70795E5-4F23-4FCA-AB98-CA1297ABA8A1 is already installed
              07/03/13 11:20:16:054 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:16:054 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:16:054 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:16:076 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:16:076 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:16:128 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:16:128 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:129 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:129 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:16:130 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:130 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:131 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:16:133 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:136 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:136 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:137 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:149 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:16:150 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:151 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:152 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\CCM\CCM.pimx' does not exist
              07/03/13 11:20:16:181 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:181 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current OS version is: Major:6, Minor:1, ServicePack:1
              07/03/13 11:20:16:182 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:182 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\CCM\CCM.pimx.
              07/03/13 11:20:16:182 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /CCM/
              07/03/13 11:20:16:186 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | START installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P7\P7.pimx
              07/03/13 11:20:16:187 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:187 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:187 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Package id 478DBDF4-F26C-4E36-A512-EC79A4CDD61E is already installed
              07/03/13 11:20:16:193 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Schema Version is 2
              07/03/13 11:20:16:193 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRelInfoRecords.
              07/03/13 11:20:16:193 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deleteAppletRegInfoRecords.
              07/03/13 11:20:16:198 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageUpgradeInfoRecords.
              07/03/13 11:20:16:198 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS deletePackageInstallationInfoRecords.
              07/03/13 11:20:16:204 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertPackageUpdateList.
              07/03/13 11:20:16:204 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:205 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRegInfoList.
              07/03/13 11:20:16:205 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:205 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS insertAppletRelInfoList.
              07/03/13 11:20:16:206 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:206 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:307 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Backup Folder Created
              07/03/13 11:20:16:307 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:901 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\P7\P7.pimx' does not exist
              07/03/13 11:20:16:931 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:931 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:932 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | XML is valid
              07/03/13 11:20:16:932 | [WARN] |  | ASU | PIM | PIM |  |  | 17068 | Failed to find Node
              07/03/13 11:20:16:932 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | SUCCESS installPackage at file \\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\AAMPackages\P7\P7.pimx.
              07/03/13 11:20:16:932 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Trying to delete back up folder for /P7/
              07/03/13 11:20:17:033 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Processing ... _pimCreateOrUpdateAAMInventory
              07/03/13 11:20:17:068 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Inventory Already present on the machine...
              07/03/13 11:20:17:068 | [INFO] |  | ASU | Setup | Utilities |  |  | 17068 | Folder does not exist
              07/03/13 11:20:17:070 | [INFO] |  | ASU | Setup | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMRefs\temp.aamref\RefCount.txt' does not exist
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIMSqlite closeDB status 0
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | FREE PIM Instance ...
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Build Version - 2.0.0.0 (BuildVersion: 2.0; BuildDate: Mon Jun 18 2012 06:00:16 )
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Logging Level verbosity Set  to 4
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Adobe\Adobe Creative Cloud\pim.db-journal' does not exist
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | CREATE PIM Instance ...
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | trying to createOrUpdatePIMDbSchema.
              07/03/13 11:20:17:071 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version on machine 2.
              07/03/13 11:20:17:072 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Current db schema version to install 2.
              07/03/13 11:20:17:072 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM DB Schema is up to date. Current schema version is 2.
              07/03/13 11:20:17:072 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | PIM Database is Up To Date.
              07/03/13 11:20:17:072 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Updater Inventory location:\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\resources\updaterinventor y.dll
              07/03/13 11:20:17:084 | [INFO] |  | ASU | PIM | PIM |  |  | 17068 | Acquired System level ACCC lock ...
              07/03/13 11:20:17:085 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Core Sync Custom Hook Executable launched with command : "\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\Tools\CCC\Utils\CoreSyncCustomHoo k.exe" -kill
              07/03/13 11:20:17:266 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Core Sync Custom Hook Executable returned with code 0
              07/03/13 11:20:22:266 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Sync Core was successfully killed
              07/03/13 11:20:22:267 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Deployment Engine launched with command : "C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe" --deploymentFile="\\carlstedt.local\dfs\files\Adobe\CC_AcroPro\Build\ASU\Tools\CCC\Uninst all\deploy\remove.xml" --uninstall
              07/03/13 11:20:22:464 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | Deployment Engine returned with code 36
              07/03/13 11:20:22:465 | [ERROR] |  | ASU | Setup | Setup |  |  | 17068 | Sync Core could not be uninstalled
              07/03/13 11:20:22:465 | [INFO] |  | ASU | Setup | Setup |  |  | 17068 | TimeLog: End Installing. Now launching PDApp
              07/03/13 11:20:22:965 | [FATAL] |  | ASU | Setup | Setup |  |  | 17068 | End Adobe Setup. Exit code: -5
              07/03/13 11:20:22:965 | [INFO] |  | ASU | Setup |  |  |  | 17068 | Event Guid generated is: '3d9ebaed-25ee-4a63-9de2-2baba7fb7cae'
              07/03/13 11:20:22:965 | [INFO] |  | ASU | Setup |  |  |  | 17068 | Event Guid generated is: '75932754-fd3d-4f94-b8a5-fa98e4ba3d70'
              07/03/13 11:20:22:966 | [INFO] |  | ASU | Setup |  |  |  | 17068 | Waiting for the async thread to get the task completed
              07/03/13 11:20:22:966 | [INFO] |  | ASU | Setup |  |  |  | 12024 | Event with guid '3d9ebaed-25ee-4a63-9de2-2baba7fb7cae' is being sent
              07/03/13 11:20:22:971 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - No default proxy present on the user machine
              07/03/13 11:20:22:971 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - proxy Url is
              07/03/13 11:20:23:374 | [INFO] |  | ASU | Setup |  |  |  | 13392 | HTTP Request Status code 200.
              07/03/13 11:20:23:374 | [INFO] |  | ASU | Setup |  |  |  | 12024 | The http request returned HTTP_Status:0 HttpCommunicator error:0
              07/03/13 11:20:23:374 | [INFO] |  | ASU | Setup |  |  |  | 12024 | Event with guid '75932754-fd3d-4f94-b8a5-fa98e4ba3d70' is being sent
              07/03/13 11:20:23:379 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - No default proxy present on the user machine
              07/03/13 11:20:23:379 | [INFO] |  | ASU | Setup |  |  |  | 12024 | GetIEProxyInfo - proxy Url is
              07/03/13 11:20:23:784 | [INFO] |  | ASU | Setup |  |  |  | 524 | HTTP Request Status code 200.
              07/03/13 11:20:23:785 | [INFO] |  | ASU | Setup |  |  |  | 12024 | The http request returned HTTP_Status:0 HttpCommunicator error:0
              07/03/13 11:20:23:785 | [INFO] |  | ASU | Setup |  |  |  | 12024 | Async thread is completed. Now exiting from function.
              07/03/13 11:20:23:785 | [INFO] |  | ASU | Setup | Utilities |  |  | 17068 | File 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMConfig.xml' does not exist
              07/03/13 11:20:23:792 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Build Version - 1.1.0.27
              07/03/13 11:20:23:792 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Logging Level verbosity Set  to 4
              07/03/13 11:20:23:792 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | The Bootstrapper Process is (-5).Stopping the installation process.
              07/03/13 11:20:23:792 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Starting to clean the partially installed payloads.
              07/03/13 11:20:23:795 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Undeployment XML created at path :: C:\Users\ANDREA~1.PET\AppData\Local\Temp\{3213A49E-6B67-4FA3-BB3F-84B70F662CB0}\\{AF25D17 3-1A09-4DE6-9155-CFA1CC163193}
              07/03/13 11:20:23:795 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Starting to launch the Adobe Installer for uninstall mode.
              07/03/13 11:20:23:795 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | Obtained Adobe Common Folder Path.
              07/03/13 11:20:23:795 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore\Setup.exe
              07/03/13 11:20:23:922 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 17600 | Process creation completed.
              07/03/13 11:20:23:923 | [FATAL] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | The return code from the Adobe Installer Process is (33).Stopping the uninstallation process.
              07/03/13 11:20:23:928 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 17600 | The install workflow is terminating.
              07/03/13 11:20:24:289 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 19244 | Process creation completed.
              07/03/13 11:20:24:289 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 19244 | utilLaunchApplicationDeelevated : The return Code from Create Process (1603).
