1. Re: Transition Pack1 Installation Failed
TBTG Jul 2, 2013 1:20 PM (in response to TBTG)Under My stuff on Adobe Exchange, I discover the Transition Pack 1 waiting to be installed.
I pressed the install option button and the process started again with no avail.
The error is:
I have tried this number of times and the same error always comes up.
We have a iMac 27" Late 2012 with:
3.4 GHz Intel Core i7
32 GB 1600 MHz DDR
NVIDIA GeForce GTX 680MX 2048 MB
OS X 10.8.4 (12E55)
Creative Cloud CC (up to date)
2. Re: Transition Pack1 Installation Failed
fgregor Jul 3, 2013 2:00 AM (in response to TBTG)Hi TBTG,
Sorry to hear you've been having trouble. I've investigated your issue and I can see that we do have a record of the purchase. Your installation problems seem to have been caused by a problem with our licensing checks for the latest version of this product, but a change has been made on our end and this should now be resolved.
Can you please try installation again?
Many thanks,
Fraser
4. Re: Transition Pack1 Installation Failed
lesavage Jul 3, 2013 9:45 AM (in response to TBTG)Hi Andrei,
The errors that you show above are different to what Fraser and I originally thought you were experiencing which were licensing issues. In the above scenario could you try the following:
1) Close the Creative Cloud application but choosing Exit in the settings menu (top right hand corner)
2) In Task Manager/Activity Monitor and kill the CEPServiceManager4 process
3) Open Extension Manager
4) Attempt the installation again through Adobe Exchange.
If this does not work then please repeat the above steps but skip step 3.
Apologies for this, it is a known issue and we are currently fixing it.
Kind regards,
Lea
5. Re: Transition Pack1 Installation Failed
TBTG Jul 4, 2013 11:20 AM (in response to lesavage)Hi Lea,
The errors above are new ones, if you look in to my second post, you would see the screen grab with the licensing issues.
I tried what you suggested, but I am stuck in steep three(open Extension Manager). It opens, but under Premier Pro CC list of extensions
there is no Transition Pack 1 product available for install.
Regards
Andrei
6. Re: Transition Pack1 Installation Failed
lesavage Jul 5, 2013 1:41 AM (in response to TBTG)Thanks Andrei,
So what dialog boxes do you see when attempting the installation? Do Extension Manager and Exchange Panel inform you that the installation was successful or is nothing displayed? In Extension Manager, are you prompted to shut down Premiere Pro during product installation?
Kind regards,
Lea
7. Re: Transition Pack1 Installation Failed
TBTG Jul 8, 2013 6:35 AM (in response to lesavage)Hi Lea,
If you look in to post #3 you would see the:
screen grab sequence of the failed installation process,
with all the answers to your questions.
Regards
Andrei
8. Re: Transition Pack1 Installation Failed
lesavage Jul 8, 2013 6:59 AM (in response to TBTG)Thanks Andrei.
So the installation is never successful. As a result I would never expect to see it listed in Extension Manager.So did any of the workarounds, suggested in post #4, bypass any of the errors outlined in post #3 to result in a successful installation? If not, then what alternative errors are you seeing instead?
Thanks in advance,
Lea
9. Re: Transition Pack1 Installation Failed
TBTG Jul 8, 2013 8:18 AM (in response to lesavage)Lea, as you can see, the installation was never successful and the option is not listed in Extension Manager.
The workarounds suggested in post #4 didn't worked. I haven't seen any other alternative errors, but the same error message posted at the end of post #3.
It's really frustrating. I have no idea what's going on.
Thanks for your time and effort on this matter,
Andrei
10. Re: Transition Pack1 Installation Failed
TBTG Jul 9, 2013 8:10 AM (in response to TBTG)A little bit of light in to this matter would be much appreciated!!! Am I the only one experiencing this? Is Extension Manager the problem? Its Premier or Creative Cloud? Could it be that there is a conflict with another app on my system? Someone out there?...
32 GB 1600 MHz DDR
OS X 10.8.4 (12E55) (up to date
Thanks in advance
Andrei
11. Re: Transition Pack1 Installation Failed
lesavage Jul 9, 2013 9:23 AM (in response to TBTG)Hi,
Usually the steps i outlined in Post 4 resolve this issue. I am surprised that you are being returned the same error when Extension Manager is not running and when it is. I would have expected different behaviour.
The error you receive does not give me the indication that the Extension Manager database is corrupted. To shed some further light to this problem could you please setup the following log settings:
Create the file 'ExManCoreLibLog.YES' in the directory: /Users/xtong/Library/Application Support/Adobe/Extension Manager CC/Log/
Create the file 'ExManLog.YES' in the directory: /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app/Contents/MacOS/
Then repeat the above steps again and send the following log files to me at lesavage at adobe dot com:
All Extension Manager logs in /Users/<username>/Library/Application Support/Adobe/Extension Manager CC/Log
Adobe Exchange Log: /Users/<username>/Library/Preferences/Adobe/Exchange
Kind regards,
Lea
13. Re: Transition Pack1 Installation Failed
lesavage Jul 10, 2013 7:31 AM (in response to TBTG)Great News! I am delighted that you are finally in a position to start using the Transition Pack.
Please be assured that a new release of the panel will be made available soon to fix the issues that you encountered.
Kind regards,
Lea
