1 Reply Latest reply on Jul 3, 2013 5:45 PM by wizbowes
    Trouble loading an xml file - claims not to be terminated correctly
    wizbowes Level 1
      I'm trying to load some data in an xml file to create a tree view.  Before that I created this code with hardcoded xml definition which works fine and creates my treeview:
      <csxs:CSExtension xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                xmlns:csxs="com.adobe.csxs.core.*"
                                                xmlns:mx="library://ns.adobe.com/flex/mx"
                                                applicationComplete="appComplete()">
                <fx:Script>
                          <![CDATA[
                                    import com.adobe.csxs.core.CSInterface;
                                    [Bindable]
                                    private var hostName:String = HostObject.mainExtension;
                                    public function appComplete():void{
                                              CSInterface.instance.autoThemeColorChange = true;
                                    import mx.collections.ICollectionView;
                                    import mx.events.ListEvent;
                                    private function tree_itemClick(evt:ListEvent):void {
                                              var item:Object = Tree(evt.currentTarget).selectedItem;
                                              if (tree.dataDescriptor.isBranch(item)) {
                                                        tree.expandItem(item, !tree.isItemOpen(item), true);
                                    private function tree_labelFunc(item:XML):String {
                                              var children:ICollectionView;
                                              var suffix:String = "";
                                                        children = tree.dataDescriptor.getChildren(item);
                                                        suffix = " (" + children.length + ")";
                                              return item[tree.labelField] + suffix;
                </fx:Script>
                <fx:Declarations>
                          <fx:XML id="myXml">
                                    <root>
                                              <folder label="One">
                                                        <folder label="One.A">
        <item label="One.A.1" />
        <item label="One.A.2" />
        <item label="One.A.3" />
        <item label="One.A.4" />
        <item label="One.A.5" />
                                                        </folder>
                                                        <item label="One.1" />
                                                        <item label="One.2" />
                                              </folder>
                                              <folder label="Two">
                                                        <item label="Two.1" />
                                                        <folder label="Two.A">
        <item label="Two.A.1" />
        <item label="Two.A.2" />
                                                        </folder>
                                              </folder>
                                    </root>
                          </fx:XML>
            </fx:Declarations>
                <mx:Tree id="tree"
                                     dataProvider="{myXml}"
                                     showRoot="false"
                                     labelField="@label"
                                     labelFunction="tree_labelFunc"
                                     width="300"
                                     rowCount="6"
                                     itemClick="tree_itemClick(event);" />
      </csxs:CSExtension>
      So that works.  Now I've created an xml file to replace the hardcoded xml.  The file looks like this:
      <?xml version="1.0" encoding="UTF-8"?>
      <root>
                                    <item label="1One.A.1" />
                                    <item label="1One.A.2" />
                                    <item label="1One.A.3" />
                                    <item label="1One.A.4" />
                                    <item label="1One.A.5" />
                          </folder>
                          <item label="1One.1" />
                          <item label="1One.2" />
                </folder>
                                    <item label="2Two.A.1" />
                                    <item label="2Two.A.2" />
                          </folder>
                </folder>
      </root>
      And I've replaced the xml creation in the code with:
      <fx:XML id="myXml" source="/Users/rob/Desktop/myXml.xml" />
      However when I try to run this it fails, giving me an error:
      Main Thread (Suspended: TypeError: Error #1085: The element type "root" must be terminated by the matching end-tag "</root>".)
      But my xml file IS terminated correctly.  Any ideas?
      Running Adobe Extension Builder 2.1 on Mac Snowleopard.
