1. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Prabhuram RJul 2, 2013 9:17 PM (in response to Jaguar72)
Unable to figure out how this is related to Flash Player! If it is, please eloborate with details of your OS and browser.
With regards,
Prabhu
2. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Jaguar72 Jul 3, 2013 6:52 AM (in response to Prabhuram R)The machine is a window xp using adobe presenter and will install because powerpoint is not install but is install. Some of the blog suggest updating flash player to 9.
It this is not case can you find some one who can address the problem
Marilyn LEvy
3. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Prabhuram RJul 3, 2013 10:59 PM (in response to Jaguar72)
Moved your discussion to Presenter so that you get the correct solution.
With regards,
Prabhu
4. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Mr SahuJul 3, 2013 11:16 PM (in response to Jaguar72)
Hi
Try installing presenter 32bit for the office 32bit and presenter 64 bit for office 64bit.
Check this link : http://helpx.adobe.com/presenter/kb/presenter-install-issue.html
Sunil
Adobe Presenter Engg Team
5. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Jaguar72 Jul 4, 2013 4:55 PM (in response to Mr Sahu)Thanks I will try this
6. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Jaguar72 Jul 5, 2013 7:45 AM (in response to Mr Sahu)can you provide some help on this one
Running Adobe Presenter7.7 in power point 2010
Run-time error 2147467259(80004005) Slide Show Window (unknown member): invalid request. Automation right not granted
7. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Mr SahuJul 8, 2013 3:50 AM (in response to Jaguar72)
Hi
Try Following instruction provided here:
I hope this would help to resolve the issue.
Sunil
Adobe presenter Engg Team
8. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Jaguar72 Jul 9, 2013 6:34 PM (in response to Mr Sahu)I need help with error below
9. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Mr SahuJul 9, 2013 10:50 PM (in response to Jaguar72)
Hi
Please try the above posted steps.
The above provided link resolve the root cause for which "Automation right not granted issue".
Here is the link once again:
Sunil
10. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Jaguar72 Jul 13, 2013 7:48 PM (in response to Mr Sahu)Trying to do a report in Adobe when almost finish when almost finish it goes away and doesn't save the work
11. Re: Error-Unable to detect Microsoft PowerPoint. You must have PowerPoint installed on this machine
Mr SahuJul 16, 2013 10:13 PM (in response to Jaguar72)
Hi
Please confirm if you are able to work on presenter now.
Was the provided link useful ??
Sunil
