4 Replies Latest reply on Jul 3, 2013 4:11 AM by Elisabetta S
    Page Tool Changes Won't Stick (CS 6)
    Elisabetta S Level 1
      I have had this happened a couple of times, although most of the time I don't have this problem, and I haven't been able to locate the option to stop this.
      Simply put, when I select the Page Tool in the toolbox and I resize the page, once I release the mouse button the page will go back to the previous size. The only way to change it has been by inputting the size manually.
      I am using Web Intent in the document properties, if it makes any difference.
      Thanks in advance!
        • 1. Re: Page Tool Changes Won't Stick (CS 6)
          Eugene Tyson Adobe Community Professional & MVP
          The dragging is just for a preview for Liquid Layouts.
          From the Help Files
          Liquid layouts
          Liquid layouts make it easier to design content for multiple page sizes, orientations, or devices. Apply liquid page rules to determine how objects
          on a page are adapted when you create alternate layouts and change the size, orientation, or aspect ratio.
          You can apply different rules to different pages, depending on the layout and the goals; only one liquid page rule can be applied to a page at a
          time. Liquid Layout is a general term that covers a set of specific liquid page rules: scale, re-center, guide-based, and object-based page rules.
          Use Liquid page rules to adapt content for output sizes.
          To adapt layouts when creating new pages in the same document using alternate layouts.
          To adapt layouts when changing existing page sizes. This is more efficient than the previous Layout Adjustment feature.
          To apply a liquid page rule, select the Page tool
          and click a page. Then choose a liquid page rule from the control bar. You can also use the
          Liquid Layouts
          To preview the effects of the applied rule, use the Page tool to drag the page handles to resize the page. The page snaps back to original size
          when you release it.
          To resize the page, press Alt (Windows) or Option (Mac OS) and then drag. Using the mouse, however, to resize the page could result in pages that are slightly off the intended size. Its more accurate to resize the page with the Height and Width widgets in the control bar.
          • 3. Re: Page Tool Changes Won't Stick (CS 6)
            Hope you read the part about holding Alt or Option when dragging
