0 Replies Latest reply on Oct 8, 2007 1:39 PM by flashed_away
    Alert showing on wrong level
    flashed_away Level 1
      I've got a SWF loaded into a level above a base SWF. The upper SWF loads in clips as and when required. One of these clips uses the Alert component to give feedback to the user when completing a booking process. Except that the Alert box doesn't show above all other clips. It shows as if loaded by the base movie - even though the function that creates the Alert exists only in the upper SWF. Lockroot is set to true in the upper SWF, but still no effect. The 'parent' parameter in the Alert.show function is set to null.
      If I publish the upper SWF locally independently, the Alerts show.
      Anybody any ideas?
