6 Replies Latest reply on Jul 4, 2013 11:12 PM by Mylenium
    AE CC Not rendering properly
    VincentDominguez
      So today I was editing and I finished, so I tried to render it so I can have in a .avi. But once I rendered it I got no errors or nothing. So I went to the desktop were it should have been placed, I loaded it and it didn't render properly after a couple of secs the music stops playing and I didn't get the glow effects or the full edit. How do I fix this tell me if you need sertain information.
        • 1. Re: AE CC Not rendering properly
          Nobody can even begin to guess without proper system information, comp settings, render settings, what footage was used and so on. Simply sounds like you used
          a) MP rendering with incompatible effects and they don't render properly and
          b) chose a render setting/ CoDec unsuitable for fluid playback on desktop
          Mylenium
          • 2. Re: AE CC Not rendering properly
            VincentDominguez Level 1
            OS: Win 7 Professional
            idk what u mean by PC setting so I'm guessing specs
            Intel core i5
            Ram: 8GB
            x64 OS
            I recorded a game with Fraps it recorded it into a .avi
            I did some slowmotion, glow, text, couple of Solids, mp3 music and I think that's it
            Rendering settings
            Quality: Best
            Resolution: Full
            Disk Cache: Read Only
            Proxies: None
            Effects: Current Settings
            Solo Switches: Current Settings
            Guid Layers: All Off
            Color Depth: Current Settings
            Frame Blending: On for checked layers
            Field Rander: Off
            Motion Blur: On for checked layers
            Time Span: Work Area Only
            Frame Rate: I tried 100 but thought that was the problem so I changed to 59.94
            I recorded the gameplay in 120fps
            Output Module
            Format: AVI
            Post-Render Action: None
            Channels: RBG
            Depth: Millions of colors
            Color: Premultiplied
            Audio
            48 kHz
            16 bit
            Stereo
            Named as xkoyyyz.avi
            Output Movie: Desktop
            It Messes up after the render, Once I play it it doesn't do the glow effect and then after around 5 secs the music stop and it stays on the first text I put.
            • 3. Re: AE CC Not rendering properly
              First, transcode your mp3 to a wav file. Mp3 audio is notorious for fouling up audio in AE. There is a lot of informatioin on this.
              Second, make sure you are looking at the Active Camera in your Composition. That's the only camera that will render.
              Third, what kind of AVI. I'll bet it's uncompressed and that will solve your playback problems. There are hundreds of avi formats. You should be using one designed for playback.
              • 4. Re: AE CC Not rendering properly
                How do I look at the active camera?
                And how do I tell if the AVI is compressed or not?
                Sorry I have no experience with cc.
                • 5. Re: AE CC Not rendering properly
                  If you didn't change anything and used the Render Cue to render your file then the file is uncompressed.
                  Please go through the getting started materials. Get familiar with the composition window and the controls. You will not be successful using AE without some serious study.
                  • 6. Re: AE CC Not rendering properly
                    What Rick said - yet another case of RTFM.
                    Mylenium
