2 Replies Latest reply on Jul 4, 2013 12:09 AM by managamanaga
    MPEG format in Premiere Pro CS5.5
    managamanaga
      Hello,
      I have an issue about file format compatibility in CS 5.5.
      I have 2 type MPEG file format, XDCAM HD 422, 1080i
      If Video ID is  768, adobe premiere not support this file, but if the video ID is 512, CS 5.5 can read this file.
      This is the file properties (can't open by premiere CS5.5) :
      Video
      Format                                   : MPEG Video
      Commercial name                          : XDCAM HD422
      Format version                           : Version 2
      Format profile                           : 4:2:2@High
      Format settings, BVOP                    : Yes
      Format settings, Matrix                  : Custom or Default
      Format settings, GOP                     : M=3, N=12 or Variable
      Format_Settings_Wrapping                 : Frame
      Duration                                 : 46mn 22s
      Bit rate                                 : 50.0 Mbps
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Active Format Description                : 0
      Frame rate                               : 25.000 fps
      Standard                                 : Component
      Color space                              : YUV
      Chroma subsampling                       : 4:2:2
      Bit depth                                : 8 bits
      Scan type                                : Interlaced
      Scan order                               : Top Field First
      Compression mode                         : Lossy
      Bits/(Pixel*Frame)                       : 0.965
      Stream size                              : 16.2 GiB
      Delay_SDTI                               : 146160
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
      Audio #1
      Format                                   : PCM
      Format settings, Endianness              : Little
      Format_Settings_Wrapping                 : Frame (AES)
      Duration                                 : 7mn 45s
      Bit rate mode                            : Constant
      Bit rate                                 : 1 152 Kbps
      Channel(s)                               : 1 channel
      Sampling rate                            : 48.0 KHz
      Bit depth                                : 24 bits
      Stream size                              : 63.9 MiB (2%)
      Delay_SDTI                               : 0
      Audio #2
      Format                                   : PCM
      Duration                                 : 7mn 45s
      Bit depth                                : 24 bits
      Delay_SDTI                               : 0
      And this is file properties that can be open by CS5.5:
      Video
      Format                                   : MPEG Video
      Duration                                 : 22s 120ms
      Color space                              : YUV
      Bit depth                                : 8 bits
      Stream size                              : 132 MiB (92%)
      Delay_SDTI                               : 0
      Audio #1
      Format                                   : PCM
      Bit depth                                : 24 bits
      Stream size                              : 3.04 MiB (2%)
      Delay_SDTI                               : 0
      Audio #2
      Format                                   : PCM
      Bit depth                                : 24 bits
      Delay_SDTI                               : 0
      Audio #3
      Format                                   : PCM
      Bit depth                                : 24 bits
      Delay_SDTI                               : 0
      Audio #4
      Format                                   : PCM
      Bit depth                                : 24 bits
      Delay_SDTI                               : 0
      Any one can help me to explain about this MPEG file format compatibility?
      Thank you very much.
        • 1. Re: MPEG format in Premiere Pro CS5.5
          Mark Mapes Adobe Employee
          I don't have a direct answer, but you might try downloading the trial of PPRO CC just to check whether it can open the "768" clip. Also, might be worth checking whether VLC will play the clip.
          I'm not even sure what the ID number signifies. The data point that caught my eye in the clip that won't load in PPRO CS5 is "Format settings, GOP: M=3, N=12 or Variable." Don't know what to make of it, but I've never seen "variable" there.
          • 2. Re: MPEG format in Premiere Pro CS5.5
            managamanaga Level 1
            Hello Mark,
            Yes, I think maybe the variable GOP is the problem.
            I have tried test some clips, and all the variable GOP can't drag into the timeline.
            The clips are ftp-out from our broadcast system storage (Harris) formerly known as Leitch. i think they put some encryption or somethink to make their product proprietary.
            i can play the clips in the windows media player classic.
            I'll try PPPRO CC and see what happen
            Thank you very much for your advice.
