5 Replies Latest reply on Jul 4, 2013 9:58 PM by AdobeUser999123
    Why batch run the script will block the ajax call?
    AdobeUser999123 Level 1
      I added a script that call an ajax to write text file, However, the script is run as usual in the acrobat program. However, if I run the sequence file through batch , the ajax call will be blocked. That means, I can only write two times no matter there are many ajax request
      Ajax code: (Get the filepath and create an ajax function)
      filePath = this.path;
      ajax = app.trustedFunction(function(fURL) {
          app.beginPriv();
          fURL = fURL + '?path=' + filePath;
          var params = { cVerb:"GET", cURL:fURL, oHandler:{
              response:function(msg,uri,e,h){}}};
          Net.HTTP.request(params);
          app.endPriv();
      Ajax code: (make an ajax request, I suspect that is caused by too frequent ajax call but in fact it is not)
      app.setTimeOut( ajax("http://localhost/DEV/ajax_optipng1.7/check.php") , 10000 ) ;
      PHP code: (call this file to write text file)
      <?php
      if (isset($_GET["path"])) {
                $productName = explode("/", $_GET["path"]);
                $fileName = $productName[count($productName) - 1];
                $productName = $productName[count($productName) - 4];
                require_once ('folderConfig.php');
                $processedFile = array();
                if (file_exists($statusFile)) {
                          $processedFile = json_decode(file_get_contents($statusFile));
                array_push($processedFile, $fileName);
                file_put_contents($statusFile, json_encode($processedFile));
      How to fix the problem? I would provide any extra information to clear the situation , thanks
