There is a global "Focus" method - Selection.getFocus(). I
don't understand exactly why that would cause problems for you -
that's a good thing isn't it? you don't need to bother with focus
listeners like you were considering. Using the Key Class(Key is a
class, not a MovieClip) to determine when the Enter key is pressed,
you could check which textfield has focus with
Alternatively, you could put an onChanged event handler on
the textfield and check if (Key.getCode() == Key.ENTER). this will
only work if your text box is multiline as the Enter key won't
trigger an onChanged otherwise.
