5 Replies Latest reply on Jul 5, 2013 6:32 AM by kglad
    Color transform help
    prodigalmaster Level 2
      Hi
      I have no experience with the colour transform class but some with the RGB hexidecimal concept.
      Let's use a little pseudo code / actionscript hybrid:
      In the following example, which doesn't work, I am trying to remove red and green colour and keep blue. How do I do this?
        colour = 0xFFFFFF;
        colourTrans.rgb = colour;
                red = 0;
                green = 0;
                blue = 1;
                colourTrans.redMultiplier = red;
                colourTrans.greenMultiplier = green;
                colourTrans.blueMultiplier = blue;
                colour = colourTrans.rgb;
        // colour outputs 0, not the new blue colour
      Thanks.
        • 1. Re: Color transform help
          use the colormatrixfilter:
          var matrix:Array;
          var filter:BitmapFilter
          function blueF(image:MovieClip):Void{
               matrix=[];
              matrix = matrix.concat([0, 0, 0, 0, 0]); // red
              matrix = matrix.concat([0, 0, 0, 0, 0]); // green
              matrix = matrix.concat([0, 0, 1, 0, 0]); // blue
              matrix = matrix.concat([0, 0, 0, 1, 0]); // alpha
              filter = new ColorMatrixFilter(matrix);
              image.filters = [filter];
          • 2. Re: Color transform help
            Thanks but the example I gave was far more simplified to get my point across saying I don't know how to *get* the value from the colourTrans... the way I am actually doing it is quite complicated and requires the colour multipliers so I can get a sequence of colours:
            import flash.geom.ColorTransform;
            import flash.geom.Transform;
            var colourTrans:ColorTransform = new ColorTransform();
            var colourBG:Number = 0x000000;
            var colour:Number = 0xFFFFFF;
            var frequency = 0.3;
            var count = 0;
            onEnterFrame = function () {
                      count += frequency;
                      red = Math.sin(frequency*count);
                      green = Math.sin(frequency*count+2);
                      blue = Math.sin(frequency*count+4);
                      trace(colour);
            • 3. Re: Color transform help
              then don't abstract what you're trying to do.  just explain what you're trying to do.
              • 4. Re: Color transform help
                Basically for each frame (onEnterFrame), return a new colour so that over time the colour turns from red to green to blue to red... like a rainbow... a sequence of colours. The red, green, and blue Math.sin code above uses the correct multipliers I think to do this (the offset is not exactly correct (2 and 4) but good enough...
                again.. all I need is a way to output the colour after the multipliers have altered the inputted colour, each frame.
                Unless there is another way to do this such as with matrixes (which I again have no experience with).
                Thanks.
                edit: and when I mean output a colour I mean store the number for the colour in the 'colour' variable.
                • 5. Re: Color transform help
                  use:
                  class com.kglad.Color_AS2 {
                      // example usage:
                      import com.kglad.Color_AS2;
                      Color_AS2.colorChangeF();
                      var ct:ColorTransform = mc.transform.colorTransform;
                      this.onEnterFrame = function(){
                      ct.rgb = Color_AS2.colorF();
                      mc.transform.colorTransform = ct
                      static var red:Object = new Object();
                      static var green:Object = new Object();
                      static var blue:Object = new Object();
                      static var colorValueA:Array = [15, 0, 128];
                      static var colorA:Array = [red, green, blue];
                      static var colorChangeA:Array = [1, -1];
                      static var primeA:Array = [3, 5, 7];
                      function Color_AS2() {
                      static function colorChangeF() {
                          for (var i:Number = 0; i < colorA.length; i++) {
                              colorA[i].val = Math.floor(Math.random() * 256);
                              colorA[i].colorChange = 2 * Math.round(Math.random()) - 1;
                      static function colorF(n:Number):Number {
                          if (!n) {
                              n = 0;
                          if (n % 2000 == 1) {
                              colorChangeF();
                              colorA[i].val += primeA[i] * colorA[i].colorChange;
                              if (colorA[i].val > 255) {
                                  colorA[i].val = 254;
                                  colorA[i].colorChange *= -1;
                              } else if (colorA[i].val < 0) {
                                  colorA[i].val = 1;
                          return colorA[0].val << 16 | colorA[1].val << 8 | colorA[2].val;
