7 Replies Latest reply on Nov 10, 2016 5:04 AM by PippoApps
    Air file is damaged
    Dawsonba Level 1
      Hi there
      For the last 2 days I've been trying to install an application but keep getting the following error message:
      "Sorry, an error has occured. The application could not be installed because the AIR file is damaged. Try obtaining a new AIR file from the application author."
      I've searched this forum and on Google for a solution, but nothing has worked so far.
      I`ve tried the following (instructions from developer`s support) more times than I`d care to think about:
      1. First uninstall Kudani if you have an existing install
      2. Make sure the Kudani application folder does not exist in c:\Program Files or c:\Program Files (x86)
      3. Check that your computer's system clock is correct. Correct the date and time if it not current.
      4. Make sure you have the latest version of the Adobe AIR runtime installed. You can download it from http://get.adobe.com/air
      5. Now try installing Kudani
      Every time, I made sure I removed all traces. I even tried uninstalling/reinstalling Air, but no luck.
      This page http://helpx.adobe.com/air/kb/troubleshoot-air-installation-windows.html recommends posting the log file contents here.
      So here they are:
      [2013-07-04:15:28:01] Runtime Installer begin with version 3.8.0.820 on Windows 7 x86
      [2013-07-04:15:28:01] Commandline is: -arp:uninstall
      [2013-07-04:15:28:01] Installed runtime (3.8.0.820) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:28:11] Relaunching with elevation
      [2013-07-04:15:28:11] Launching subprocess with commandline c:\program files (x86)\common files\adobe air\versions\1.0\resources\adobe air updater.exe -eu
      [2013-07-04:15:28:11] Runtime Installer begin with version 3.8.0.820 on Windows 7 x86
      [2013-07-04:15:28:11] Commandline is: -stdio \\.\pipe\AIR_17076_0 -eu
      [2013-07-04:15:28:11] Installed runtime (3.8.0.820) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:28:11] Starting runtime uninstall. Uninstalling runtime version 3.8.0.820
      [2013-07-04:15:28:11] Reinstalling c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\setup.msi
      [2013-07-04:15:28:16] Uninstalling product with GUID {0A5B39D2-7ED6-4779-BCC9-37F381139DB3}
      [2013-07-04:15:28:24] Runtime Installer end with exit code 0
      [2013-07-04:15:28:28] Elevated install completed
      [2013-07-04:15:28:28] Runtime Installer end with exit code 0
      [2013-07-04:15:33:26] Runtime Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:33:26] Commandline is:
      [2013-07-04:15:33:26] No installed runtime detected
      [2013-07-04:15:33:29] Relaunching with elevation
      [2013-07-04:15:33:29] Launching subprocess with commandline c:\users\dabber~1\appdata\local\temp\airbf1d.tmp\adobe air installer.exe -ei
      [2013-07-04:15:33:33] Runtime Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:33:33] Commandline is: -stdio \\.\pipe\AIR_15760_0 -ei
      [2013-07-04:15:33:33] No installed runtime detected
      [2013-07-04:15:33:33] Starting silent runtime install. Installing runtime version 3.7.0.2090
      [2013-07-04:15:33:34] Installing msi at c:\users\dabber~1\appdata\local\temp\airbf1d.tmp\setup.msi with guid {A0087DDE-69D0-11E2-AD57-43CA6188709B}
      [2013-07-04:15:33:38] Runtime Installer end with exit code 0
      [2013-07-04:15:33:38] Elevated install completed
      [2013-07-04:15:33:42] Launching subprocess with commandline c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Resources\Adobe AIR Updater -installupdatecheck
      [2013-07-04:15:33:42] Runtime Installer end with exit code 0
      [2013-07-04:15:33:43] Runtime Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:33:43] Commandline is: -installupdatecheck
      [2013-07-04:15:33:43] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:33:43] Performing pingback request
      [2013-07-04:15:33:45] Pingback request completed with HTTP status 200
      [2013-07-04:15:33:45] Starting runtime background update check
      [2013-07-04:15:33:45] Begin Background update download from http://airdownload.adobe.com/air/3/background/windows/x86/patch/3.7.0.2090/update
      [2013-07-04:15:33:45] Unpackaging http://airdownload.adobe.com/air/3/background/windows/x86/patch/3.7.0.2090/update to C:\Users\dabber300\AppData\Roaming\Adobe\AIR\Updater\Background
      [2013-07-04:15:33:45] Runtime update not available
      [2013-07-04:15:33:45] Unpackaging cancelled
      [2013-07-04:15:33:45] Runtime Installer end with exit code 0
      [2013-07-04:15:34:53] Application Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:34:53] Commandline is: C:\Users\dabber300\Documents\kudani.air
      [2013-07-04:15:34:53] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:34:54] Unpackaging file:///C:/Users/dabber300/Documents/kudani.air to C:\Users\dabber300\AppData\Local\Temp\fla320B.tmp
      [2013-07-04:15:35:06] Application signature verified
      [2013-07-04:15:35:06] Unpackaging/validation complete
      [2013-07-04:15:35:06] No app located for appID 'com.pageone.Kudani' and pubID ''
      [2013-07-04:15:35:15] Converting unpackaged application to a native installation package in C:\Users\dabber300\AppData\Local\Temp\fla8662.tmp
      [2013-07-04:15:35:28] Native installation package creation succeeded
      [2013-07-04:15:35:28] Starting app installation to C:\Program Files (x86)\PageOneTraffic. Installing app com.pageone.Kudani version 0.0.2 using the source file at file:///C:/Users/dabber300/Documents/kudani.air
      [2013-07-04:15:35:28] Got an unexpected fatal error while in stateInstalling: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: Directory can't be written to" errorID=5006]
      [2013-07-04:15:35:28] Launching subprocess with commandline c:\Program Files (x86)\Common Files\Adobe AIR\Versions\1.0\Adobe AIR Application Installer -runtime "c:\Program Files (x86)\Common Files" -silent -logToStdout -url -location "C:\Program Files (x86)\PageOneTraffic" -desktopShortcut -programMenu file:///C:/Users/dabber300/Documents/kudani.air
      [2013-07-04:15:35:28] Relaunching with elevation
      [2013-07-04:15:35:33] Application Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:35:33] Commandline is: -stdio \\.\pipe\AIR_19136_0 -runtime "c:\Program Files (x86)\Common Files" -silent -logToStdout -url -location "C:\Program Files (x86)\PageOneTraffic" -desktopShortcut -programMenu file:///C:/Users/dabber300/Documents/kudani.air
      [2013-07-04:15:35:33] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:35:34] Unpackaging file:///C:/Users/dabber300/Documents/kudani.air to C:\Users\dabber300\AppData\Local\Temp\flaCD5F.tmp
      [2013-07-04:15:35:47] Application signature verified
      [2013-07-04:15:35:47] Unpackaging/validation complete
      [2013-07-04:15:35:47] No app located for appID 'com.pageone.Kudani' and pubID ''
      [2013-07-04:15:35:47] Converting unpackaged application to a native installation package in C:\Users\dabber300\AppData\Local\Temp\fla19A.tmp
      [2013-07-04:15:36:00] Native installation package creation failed: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
      [2013-07-04:15:36:00] Elevated install failed: error 5005 Unhandled exception Error: EndUpdateResource: Windows Error #5
      [2013-07-04:15:36:05] Application Installer end with exit code 7
      [2013-07-04:15:36:32] Application Installer end with exit code 7
      [2013-07-04:15:36:36] Application Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:36:36] Commandline is: C:\Users\dabber300\Documents\kudani.air
      [2013-07-04:15:36:36] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:36:36] Unpackaging file:///C:/Users/dabber300/Documents/kudani.air to C:\Users\dabber300\AppData\Local\Temp\flaC313.tmp
      [2013-07-04:15:36:50] Application signature verified
      [2013-07-04:15:36:50] Unpackaging/validation complete
      [2013-07-04:15:36:50] No app located for appID 'com.pageone.Kudani' and pubID ''
      [2013-07-04:15:36:54] Converting unpackaged application to a native installation package in C:\Users\dabber300\AppData\Local\Temp\fla67A.tmp
      [2013-07-04:15:37:06] Native installation package creation failed: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
      [2013-07-04:15:37:17] Application Installer end with exit code 7
      [2013-07-04:15:39:35] Application Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:39:35] Commandline is: C:\Users\dabber300\Documents\kudani.air
      [2013-07-04:15:39:35] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:39:37] Unpackaging file:///C:/Users/dabber300/Documents/kudani.air to C:\Users\dabber300\AppData\Local\Temp\fla82B9.tmp
      [2013-07-04:15:39:56] Application signature verified
      [2013-07-04:15:39:56] Unpackaging/validation complete
      [2013-07-04:15:39:56] No app located for appID 'com.pageone.Kudani' and pubID ''
      [2013-07-04:15:40:04] Converting unpackaged application to a native installation package in C:\Users\dabber300\AppData\Local\Temp\flaEC26.tmp
      [2013-07-04:15:40:18] Native installation package creation failed: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
      [2013-07-04:15:40:29] Application Installer end with exit code 7
      [2013-07-04:15:41:21] Application Installer begin with version 3.7.0.2090 on Windows 7 x86
      [2013-07-04:15:41:21] Commandline is: C:\Users\dabber300\Documents\kudani.air
      [2013-07-04:15:41:21] Installed runtime (3.7.0.2090) located at c:\Program Files (x86)\Common Files\Adobe AIR
      [2013-07-04:15:41:22] Unpackaging file:///C:/Users/dabber300/Documents/kudani.air to C:\Users\dabber300\AppData\Local\Temp\fla1E1E.tmp
      [2013-07-04:15:41:35] Application signature verified
      [2013-07-04:15:41:35] Unpackaging/validation complete
      [2013-07-04:15:41:35] No app located for appID 'com.pageone.Kudani' and pubID ''
      [2013-07-04:15:42:06] Converting unpackaged application to a native installation package in C:\Users\dabber300\AppData\Local\Temp\flaCBCB.tmp
      [2013-07-04:15:42:17] Native installation package creation failed: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Unhandled exception Error: EndUpdateResource: Windows Error #5" errorID=0]
      [2013-07-04:15:42:23] Application Installer end with exit code 7
