5 Replies Latest reply on Jul 27, 2013 11:50 PM by tzufloigen
    Can't get text paths if there are groups
    tzufloigen
                tell myDocument
                          set myPitems to (every text path of every page item of every page) whose contents = ""
                          repeat with Pitem in myPitems
        display dialog "got it"
                                    delete Pitem's parent
                  end repeat
                end tell
      This is a working script - as long as there is nothing grouped in the document. (Took a while to figure out why it was throwing an error!) None of the text paths I need are grouped, incidentally.
      I am deleting all objects that have "text on a path" set up but no text on them.
      What am I doing wrong? Do I need to ungroup everything first? Is there an easy way to temporarily ungroup everything?
      Thank you!
        • 1. Re: Can't get text paths if there are groups
          tzufloigen Level 1
          I decided to just ungroup everything, but for anyone reading this later, this doesn't really work - it deletes the second item of linked text paths, but doesn't consider the contents of the first text path as "".
          • 2. Re: Can't get text paths if there are groups
            tzufloigen Level 1
            This is pretty sad... I'm at this for hours and can't figure it out, I post here and voila progress!
            For anyone else with this issue, you may need to first remove all <FEFF> characters.
            Still don't know how to regroup my groups, though.
            • 3. Re: Can't get text paths if there are groups
              ScreenNamesUnavailable
              G'day
              i couldn't get
              to work in CS5
              But if none of your text paths are in groups, you can just bypass the page items that are groups :
                        tell myDocument
                                  set myPitems to every page item whose class is not group
                                  repeat with x in myPitems
                                            try
                                                      set myEmptyPath to ((text path 1 of x) whose contents = "")
                delete parent of myEmptyPath
                                            end try
                                  end repeat
                        end tell
              Hope that helps
              m.
              • 4. Re: Can't get text paths if there are groups
                ScreenNamesUnavailable Level 1
                Alternatively .....
                if you need to drill into the groups you can do it like this :
                                    set myGroups to every page item whose class is group
                                    repeat with y in myGroups
                                              set myPitems to page items of y
                                                        try
                                                        end try
                                              end repeat
                                    end repeat
                but that will only get you down one level (ie. not helpful if you have grouped groups, etc.)
                m.
                • 5. Re: Can't get text paths if there are groups
                  tzufloigen Level 1
                  Thank you so much!
                  I have now had time to test completely, and this does solve my issues, saving me untold amounts of time. Many, many thanks!
