2 Replies Latest reply on Jul 8, 2013 1:45 AM by Wander5
    Help in Applescript Mail option
    Wander5
      Hi Forum,
      I'm using tis applescript, to check the folder for files and sent mail via applescript.
      It works quiet good. The problem is if the document does not contain any files, also the mail is sent to the receipient.
      I'm requesting forum , to correct this applescript, to send the mail only if the files are found inside the folder.
      on run
                set myFolder to "/Users/wander5/Desktop/QuarkRescueFolder"
                set {TID, text item delimiters} to {text item delimiters, linefeed}
                tell application "Finder" to set myFiles to name of files of (POSIX file myFolder as alias)
                set newNames to paragraphs of (do shell script "sed 's/\\(.*\\)\\((.*)\\)/\\2 \\1/' <<< " & quoted form of (myFiles as text))
                repeat with i from 1 to count myFiles
                          tell application "System Events" to set name of (first file of folder myFolder whose name is (item 1 of myFiles)) to (item 1 of newNames)
                end repeat
                set text item delimiters to TID
                set fileList to list folder myFolder without invisibles
                repeat with tFile in fileList
                          set recipientName to "Wander5"
                          set recipientAddress to "Wander5@yahoo.com"
                          set theSubject to "Please check Files has been completly copied from server"
                          set theContent to "check files have been copied"
                          tell application "Mail"
        # # Create the message
                                    set theMessage to make new outgoing message with properties {subject:theSubject, content:theContent, visible:true}
        ##Set a recipient
                                    tell theMessage
        make new to recipient with properties {name:recipientName, address:recipientAddress}
        ##Send the Message
                                              send
                                    end tell
                          end tell
        ##end tell
                end repeat
      end run
      Many thanks,
        • 1. Re: Help in Applescript Mail option
          Muppet Mark Level 5
          I didn't test but don't you just need to test fileList's length/count before you loop the list…?
          on run
                    end repeat
                    if length of fileList > 0 then -- Its not an empty list…
            ##Set a recipient
                                                  tell theMessage
            ##Send the Message
                                                            send
                                                  end tell
                                        end tell
                              end repeat
                    end if
          end run
          • 2. Re: Help in Applescript Mail option
            Wander5 Level 1
            superb! superb! superb! Muppet Mark,
            I have decoded the repeat function, so that the loop stops and will mail me only once, even if there are number of files inside. (which is what I need).
            ##repeat with tFile in fileList
            ## end repeat
            thanks you so much for the tweaks you have done. very very helpfull and so kind of you..
            Can i get help from you, to check, from where the folder or files have been pasted (i'm thinking to get the IP address of the pasted folder). parent location of the folder.
            thanks so much Mark!... The timely help and unforgettable one.
            thanks,
            @Wander..
