2 Replies Latest reply on Jul 5, 2013 8:23 AM by xxyy1234
    ePub
    xxyy1234
      Using Robohelp 10.  Some text displays larger than other text, apparenty because of whether it is copied into the Design Editor from other sources.  I cannot get it to change.  How can I change this?
        • 1. Re: ePub
          Jeff_Coatsworth Adobe Community Professional & MVP
          Are you seeing this in your project or in the generated output? It’s a little unclear from your question. If it’s in your project, then your styles are probably being overridden by some inline styling that probably got carried in when pasted; you’ll need to root that out to apply your styles. If it’s in your generated output, then suspect something in the application of the CSS being used.
          • 2. Re: ePub
            xxyy1234 Level 1
            Yes, it only appears in the generated output.  Thanks.
