9 Replies Latest reply: Aug 17, 2013 10:40 PM by Varun_Nohria RSS
    How do I make a process/service asyncronous.
    JosephDoggie Community Member
      When I invoke a long-lived process from another process, I get the following run-time error:
      "The Long Lived Service x cannot be invoked synchronously."
      How can I change the process/service so that is invoked asynchronously?
      Thanks.
      {NOTE:  It'd be really nice to be able to copy-n-paste into these forum windows.}
        • 1. Re: How do I make a process/service asyncronous.
          WASIL Adobe Employee
          You should also change the calling process to be long-lived, with this you'll be able to invoke it asynchronously. In workbench, right click the process, select configure, click on Advanced tab and change the "Type" to "long-lived".
          Hope this helps.
          Wasil
          • 2. Re: How do I make a process/service asyncronous.
            Thanks for the answer.  It appears to be *part* of the solution.
            However, I am now getting a run-time error "Long lived operation and is not supported on transient branches".
            Unfortunately, it doesn't "point' to a specific process or sub-process that I need to change.
            Any ideas?
            I am not allowed to post my code or files, at least not w/o special permission; however, one long-term process is invoking another long-term process ....
            • 3. Re: How do I make a process/service asyncronous.
              I am not sure what's the version of LiveCycle you are using  . In case, it is 7.x, please refer to this : http://ncifrederick.cancer.gov/about/readingroom/css/COTS/LiveCycle/Adobe-LiveCycle-Workfl ow.pdf
              If not, just try to find the branch which is transient/synchronous and change it to asynchronous(you can also refer to server log file to get some more info).
              Wasil
              • 4. Re: How do I make a process/service asyncronous.
                I am using Live Cycle Workbench ES3, version 10.0.2.x
                • 5. Re: How do I make a process/service asyncronous.
                  Can you please share your lca through Acrobat.com ?
                  • 6. Re: How do I make a process/service asyncronous.
                    Mark Lindberg Community Member
                    You can use a Script Object within your Short-Lived process to invoke a long-lived process, if that is the issue.
                    import javax.servlet.ServletException;
                    import java.util.*;
                    import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
                    import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
                    import com.adobe.idp.dsc.InvocationRequest;
                    import com.adobe.idp.dsc.InvocationResponse;
                    import com.adobe.idp.dsc.clientsdk.ServiceClient;
                    import com.adobe.idp.Document;
                    String strResultFlg = "FAIL";  //Assume failure status until completed successfully
                    Document inXML = patExecContext.getProcessDataDocumentValue("/process_data/formData");
                    System.out.println("formData =  " +  inXML);
                          try
                                // Create the service client factory
                                ServiceClientFactory myFactory = ServiceClientFactory.createInstance();
                                //Create a ServiceClient object
                                ServiceClient myServiceClient = myFactory.getServiceClient();
                                //Create a Map object to store the XML input parameter value
                                Map params = new HashMap();
                                params.put("formData", inXML);
                                //Create an InvocationRequest object
                                InvocationRequest lcRequest =  myFactory.createInvocationRequest(
                                    "<app_Name>/processes/<Process_Name>", //Specify the long-lived process name
                                        "invoke",           //Specify the operation name
                                        params,               //Specify input values
                                       false);               //Create an asynchronous request
                                //Send the invocation request to the long-lived process and
                                //get back an invocation response object
                                InvocationResponse lcResponse = myServiceClient.invoke(lcRequest);
                                String invocationId = lcResponse.getInvocationId();
                             // Print the verification message
                              System.out.println(invocationId + " was successfully invoked." );
                                 strResultFlg = "DONE";
                            }catch (Exception e) {
                                System.out.println("Exception thrown while trying to invoke process " +      e.getMessage());
                    patExecContext.setProcessDataValue("/process_data/@strResultFlg", strResultFlg);
                    Hope this helps
                    Mark
                    • 7. Re: How do I make a process/service asyncronous.
                      Sunil Gupta Community Member
                      @JosephDoggie
                      Did you get the solution of your posted problem?
                      Regards
                      Sunil
                      • 8. Re: How do I make a process/service asyncronous.
                        Bibhu Bikash Nayak Community Member
                        How about making a custom event of the short lived process of event Throw type and use the same event as an Event start point in the long lived process?
                        Lets say you have 1 Short Lived process which will accept a document variable as an input and you have one Longlived process which will use that document variable for creating a Task in workspace.
                        So what gonna you do is create a custom event in the short lived process and capture the document variable. Then in the long lived process use the same event as a Event start point use Xpath to map the event data value to a process variable.
                        One more thing you can try i.e invoking the long lived process through a webservice.
                        Does this help?
                        Bibhu.
                        • 9. Re: How do I make a process/service asyncronous.
                          Varun_Nohria Community Member
                          I think it is a bug or a limitation in ES3.
                          I quickly tested this scenario (long-lived process calling another long-lived process) in ES2 SP2 and it is working.
                          On ES3, its not working and "Long lived operation and is not supported on transient branches" exception is thrown in server logs.
                          Request you to open a Support case for this issue by contacting Adobe LiveCycle Support and we can take it from there.
                          Regards,
                          Varun Nohria
