4 Replies Latest reply on Jul 6, 2013 4:56 AM by pixxxel schubser
    Create Layer with BG Color
    StrongBeaver Level 3
      function layer() {
      Application.activeDocument
      Application.backgroundColor (blue = 34, green = 12, red = 1)
      layer()
      I want to create a NewLayer, with a specific background color, the code above is not working.
        • 1. Re: Create Layer with BG Color
          Michael L Hale Level 5
          You really need to read the scripting guide.
          Application is a Photoshop Class. To reference that class you use app. So the first line in the function should be app.activeDocument. Even then that line does not do anything except return a document object. If you do not store the returned object in a variable you might as well delete that line.
          app.backgroundColor is an app property, not a method. So the () are not used. That property either returns a SolidColor object that is the current background color or you can assign it a new color something like this
          var myColor = new SolidColor();
          myColor.rgb.red = 1;
          myColor.rgb.green = 12;
          myColor.rgb.blue - 34;
          app.backgroundColor = myColor;
          But that does not create a new layer and I am not sure what kind of layer you want. Do you want to create a new artLayer then fill it with your color or do you want to create a new SolidFill adjustment layer using that color.
          To create a new artLayer you do something like
          app.activeDocument.artLayers.add();
          To create a new adjustment layer you would need to use Action Manager( scriptlistener ).
          • 2. Re: Create Layer with BG Color
            pixxxel schubser MVP & Adobe Community Professional
            @StrongBeaver,
            a layer has not a background color. And your code is fully wrong. Search in the OMV for the properties of document and layers.
            // http://forums.adobe.com/thread/1248703?tstart=0
            // LayerFillWithDefinedColor.jsx
            // regards pixxxelschubser
            // define your color
            aColor = new SolidColor();
            aColor.rgb.red = 1;
            aColor.rgb.green = 12;
            aColor.rgb.blue = 34;
            // define your document
            var aDoc = activeDocument;
            // fill the active layer, but be sure, this is an artLayer !
            aDoc.selection.fill( aColor);
            // add a new layer
            var aLayer = aDoc.artLayers.add();
            // and fill again
            Have fun
            <edit>
            I was too slow. And what Michael L Hale said.
            </edit>
            • 3. Re: Create Layer with BG Color
              I will review the scripting guide.  The script posted, has cleared up a little for me, thanks
              • 4. Re: Create Layer with BG Color
                I think your behavior is hardly fair.
                Why you not marks the correct answers as helpful or correct?
