1 Reply Latest reply on Jul 8, 2013 2:28 PM by Lucia Lao
      • 1. Re: I NEED A FORM THAT WILL PUT NAME IN ALPHABETIC ORDER.  THIS FORM NEEDS TO HAVE COLUMNS WITH HEADERS.
        Lucia Lao Employee Moderator
          Is your question in the context of the responses that you collect (this is the View Responses tab) or the actual form that your end users will see?
        In a nutshell, (1)  a field in your form corresponds to a column in the responses table. (2) the caption text of the form field will be the column header (show up at the top of the column). (3) to list names in alphabetical in your form, you can use choices fields, like multiple choices field or drop down field - you will have to enter the name in alphabetical order manually.
        Hope this helps,
        Lucia
