4 Replies Latest reply: Jul 22, 2013 6:27 PM by jefferis RSS
    CS6 Crashes on Open, Mac 10.8.4
    jefferis Community Member
      Tried opening Illustrator today after updating Mac OS security yesterday.  All I'm getting are crashes on AI after the splash screen.
      I saw a similar link on Illustrator CC suggesting a Java update, but the link to that update no longer exists as a download. Apple removed it.
      Process:         Adobe Illustrator [5415]
      Path:            /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
      Identifier:      com.adobe.illustrator
      Version:         691 (16.0.4)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [299]
      User ID:         501
      Date/Time:       2013-07-08 14:10:11.308 -0400
      OS Version:      Mac OS X 10.8.4 (12E55)
      Report Version:  10
      Interval Since Last Report:          44022 sec
      Crashes Since Last Report:           4617
      Per-App Interval Since Last Report:  1234 sec
      Per-App Crashes Since Last Report:   4
      Anonymous UUID:                      8C5ABDFB-33A6-8E71-3744-4E67C3ADBE31
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes: EXC_I386_GPFLT
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   com.adobe.illustrator                   0x0000000100c904db std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::erase(SPSUAS const&) + 19531
      1   com.adobe.illustrator                   0x0000000100c8f902 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::erase(SPSUAS const&) + 16498
      2   com.adobe.illustrator                   0x0000000100c8e214 std::_Rb_tree<SPSUAS, std::pair<SPSUAS const, int>, std::_Select1st<std::pair<SPSUAS const, int> >, std::less<SPSUAS>, std::allocator<std::pair<SPSUAS const, int> > >::erase(SPSUAS const&) + 10628
      3   com.adobe.illustrator                   0x0000000100992299 0x100000000 + 10035865
      4   com.adobe.illustrator                   0x000000010099364a 0x100000000 + 10040906
      5   com.adobe.illustrator                   0x0000000100705feb 0x100000000 + 7364587
      6   com.adobe.illustrator                   0x00000001008487ce 0x100000000 + 8685518
      7   com.adobe.illustrator                   0x0000000100704a90 0x100000000 + 7359120
      8   com.adobe.illustrator                   0x00000001006f4d04 0x100000000 + 7294212
      9   com.adobe.illustrator                   0x0000000100163528 0x100000000 + 1455400
        • 1. Re: CS6 Crashes on Open, Mac 10.8.4
          Mike Gondek Community Member
          system preferences >> other >> java >> update
          Java 7 Update 25 is most current (At this time)
          if that does fix illustrator try resetting your preferfences, and later try booting illustrator with shift down.
          • 2. Re: CS6 Crashes on Open, Mac 10.8.4
            Hi Mike.  I'm having trouble seeing this Other option in Mac system preferences.  I don't have an other category in my system pref panel in 10.8.4.   The latest download from Apple is Java SE 6 to version 1.6.0_51   but I think that is the version I have installed with yesterday's update.   I don't have a java applet I can find on my computer to check it's independent version number...
            However, holding down shift did allow me to boot AI...
            • 3. Re: CS6 Crashes on Open, Mac 10.8.4
              I can boot with shift key down, BUT the program is unusable when I do.  Nothing seems to work and when I open a file it says something about stroke overlay plugin not working and things can't be modified.  The programs is completely unresponsive.
              AI has turned into a doorstop.
              BTW, I updated to Java 7 and it did NOT help
              Process:         Adobe Illustrator [3258]
              Parent Process:  launchd [394]
              User ID:         501
              Date/Time:       2013-07-12 17:09:10.881 -0400
              Report Version:  10
              Interval Since Last Report:          2984 sec
              Crashes Since Last Report:           129
              Per-App Interval Since Last Report:  24 sec
              Per-App Crashes Since Last Report:   1
              Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000009
              VM Regions Near 0x9:
                  __TEXT                 0000000100000000-0000000101877000 [ 24.5M] r-x/rwx SM=COW  /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
              • 4. Re: CS6 Crashes on Open, Mac 10.8.4
                Updated CS6 today and it opened for me once, with an error message about 10 included plugins (from Adobe) not loading properly.  I tried to export to FXG and it crashed and now crashes every time again:
                  ReportCrash[39234]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 3. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
                  Adobe Illustrator[39222]: Error loading /Applications/Adobe Illustrator CS6/Plug-ins.localized/Extensions.localized/ASLib.aip/Contents/MacOS/ASLib:  dlopen(/Applications/Adobe Illustrator CS6/Plug-ins.localized/Extensions.localized/ASLib.aip/Contents/MacOS/ASLib, 262): no suitable image found.  Did find:
                    /Applications/Adobe Illustrator CS6/Plug-ins.localized/Extensions.localized/ASLib.aip/Contents/MacOS/ASLib: mach-o, but wrong architecture
                Restarted with SHIFT down and it will start, but then I tried to export a file and it crashed again:
                Process:     Adobe Illustrator [39240]
                Parent Process:  launchd [316]
                User ID:     501
                Date/Time:   2013-07-22 21:26:12.365 -0400
                Report Version:  10
                Interval Since Last Report:      128615 sec
                Crashes Since Last Report:       1570
                Per-App Interval Since Last Report:  1186 sec
                Per-App Crashes Since Last Report:   3
                Exception Codes: KERN_INVALID_ADDRESS at 0xffffffffffffffd8
                VM Regions Near 0xffffffffffffffd8:
                --> shared memory      00007ffffffee000-00007ffffffef000 [4K] r-x/r-x SM=SHM
                Application Specific Information:
                Performing @selector(dispatchMenuSelection:) from sender DVAMacMenuItem 0x109291d10
                0   com.adobe.illustrator     0x00000001006dfe1d 0x100000000 + 7208477
                1   com.adobe.illustrator     0x00000001006e153b 0x100000000 + 7214395
                2   com.adobe.illustrator     0x00000001006e2a19 0x100000000 + 7219737
                3   com.adobe.illustrator     0x0000000100706934 0x100000000 + 7366964
                4   com.adobe.illustrator     0x0000000100774ec8 0x100000000 + 7818952
                5   com.adobe.illustrator     0x000000010088e4c6 0x100000000 + 8971462
                6   com.adobe.illustrator     0x000000010088f024 0x100000000 + 8974372
                7   com.adobe.illustrator     0x000000010089045d 0x100000000 + 8979549
                8   com.adobe.illustrator     0x000000010089c247 0x100000000 + 9028167
                9   com.adobe.illustrator     0x0000000100ac42e9 0x100000000 + 11289321
                10  com.adobe.illustrator     0x0000000100ac49b8 0x100000000 + 11291064
                11  com.adobe.illustrator     0x000000010046f54e 0x100000000 + 4650318
                12  com.adobe.illustrator     0x000000010048bd13 0x100000000 + 4766995
                13  com.adobe.illustrator     0x0000000100766084 0x100000000 + 7757956
                14  com.adobe.exo.framework   0x0000000108ee55c3 exo::uisupport::CommandHandler::HandleCommand(int) + 259
                15  com.adobe.exo.framework   0x0000000108ee5614 exo::uisupport::CommandHandler::DoCallMyCommandChain(int) + 36
                16  com.adobe.exo.framework   0x0000000108ee501e exo::uisupport::CommandHandlerBase::CallCommandChain(int) + 62
                17  com.adobe.exo.framework   0x0000000108e6f437 exo::app::OS_AppBase::DispatchMenuCommand(int) + 119
                18  com.adobe.dvacore.framework   0x0000000107eefe4b int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 123
                19  com.adobe.illustrator     0x0000000100767ccb 0x100000000 + 7765195
                20  com.adobe.dvacore.framework   0x0000000107eeeeda void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 250
                21  com.adobe.dvacore.framework   0x0000000107ef29bd void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 93
                22  com.adobe.exo.framework   0x0000000108e70ebb -[ExoMacApplication handleMenuCommand:] + 187
                23  com.apple.AppKit          0x00007fff85848959 -[NSApplication sendAction:to:from:] + 342
                24  com.apple.AppKit          0x00007fff8597e36c -[NSMenuItem _corePerformAction] + 406
                25  com.apple.AppKit          0x00007fff8597e05a -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 133
                26  com.adobe.dvaui.framework 0x00000001086209ad -[DVAMacMenu performActionForItemAtIndex:] + 61
                27  com.apple.AppKit          0x00007fff8566b20f -[NSMenu _internalPerformActionForItemAtIndex:] + 36
                28  com.apple.AppKit          0x00007fff8566b097 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 135
                29  com.apple.AppKit          0x00007fff85977165 NSSLMMenuEventHandler + 342
                30  com.apple.HIToolbox       0x00007fff81248d1a DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1206
                31  com.apple.HIToolbox       0x00007fff812481e9 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 410
                32  com.apple.HIToolbox       0x00007fff8125dfc9 SendEventToEventTarget + 40
                33  com.apple.HIToolbox       0x00007fff81294ca9 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 443
                34  com.apple.HIToolbox       0x00007fff81239a21 SendMenuCommandWithContextAndModifiers + 59
                35  com.apple.HIToolbox       0x00007fff812399d3 SendMenuItemSelectedEvent + 254
                36  com.apple.HIToolbox       0x00007fff8123985f FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 94
                37  com.apple.HIToolbox       0x00007fff812158bb MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 605
                38  com.apple.HIToolbox       0x00007fff81214ec8 _HandleMenuSelection2 + 565
                39  com.apple.AppKit          0x00007fff858368c6 _NSHandleCarbonMenuEvent + 245
                40  com.apple.AppKit          0x00007fff85758a9f _DPSNextEvent + 2073
                41  com.apple.AppKit          0x00007fff85757df2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                42  com.apple.AppKit          0x00007fff8574f1a3 -[NSApplication run] + 517
                43  com.adobe.exo.framework   0x0000000108e6e767 exo::app::OS_AppBase::RunEventLoop() + 55
                44  com.adobe.illustrator     0x0000000100765bc8 0x100000000 + 7756744
                45  com.adobe.illustrator     0x0000000100704b95 0x100000000 + 7359381
                46  com.adobe.illustrator     0x00000001006f4d04 0x100000000 + 7294212
                47  com.adobe.illustrator     0x0000000100163528 0x100000000 + 1455400
